Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 03-28-2011, 09:30 PM
mudgoat mudgoat is offline
Vehicle: 2010 dodge ram 1500 sport
mudgoat is on a distinguished road
Default jet performance 180 thermostat question
This weekend i installed one of the jet performance thermostats, I have the stage 1 chip in my truck already. Everything seemed to work fine for the 1 or 2 i was out after installing it, but now today in the morning my truck wouldn't blow hot air and it would spike up to really hot then go back down to the medium mark then the hot air would blow, then i look down and the needle is half way between cold and medium temperature and it was blowing hot air, but then it would go back up and it would blow cold air for a bit.
Basically the temperature gauge is all over the place, and the heat is cold and hot, So i am wondering if anyone else has had the same problem as me at all when installing this or what You think could be causing this. I did put the little pin at 12 o'clock as i seen on a how to video on you tube. and the reason i changed it was because it was leaking from that housing, and it always smelt like burnt coolant, since then its stopped leaking and doesn't smell anymore.
Now i might have a big air lock but the radiator hose is full of coolant, however it hasn't sucked much out of the coolant reservoir either since i installed the new thermostat, which seems kinda weird.
Anyways if someone could give me some advice or if they have had similar problems. That would be appreciated.
Thanks
Old 03-28-2011, 10:13 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
Hmmmmm.... I am running that same thermostat and have had 0 issues. At running temp my gauge reads about half way between cold and half. Have you tried taking off the radiator cap and starting it up and letting it run till it reaches temp and see if the radiator level drops at all? Air in the line is the only thing that I could think of, but I am not a mechanic. I only lost about half a gallon of coolant during my swap, so I ran it to temp with cap off and added new coolant so there would be no air in the line. Hope you get that worked out. May be a defective thermostat.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 03-30-2011, 06:30 AM
chopperman chopperman is offline
chopperman is on a distinguished road
Classic example of air in the system. You introduced air into the system as soon as you took off the thermostat. Check your overflow tank to see if the level rises or not. Most likley going to have to purge the air out of it, not hard to do.
Old 04-01-2011, 11:48 AM
ike43's Avatar
ike43 ike43 is offline
Vehicle: 2006 1500 4x4
Trim Level: quad
ike43 is on a distinguished road
i installed mine about a month ago and it was always steady between cold and half on the gauge, but now it moves alot from 180 to 200 when idleing, i seems that the tstat is closing and opening too much it should stay open when at 180 , it drops fast when it reaches 200 i suspect faulty t stat
Old 04-10-2011, 12:24 AM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Hope you go this resolved by now...
It won't pull from the bottle very well when there is still air in the system. after the truck has cooled off, check the level and top off as necessary until the level no longer goes down. You can also run it up till the thermostat opens with the cap off to get any air out of the block.
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
pcd performance stage 1 chip ? question nitro1965 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 01-08-2012 11:43 PM
2002 RAM 1500 5.9L 4x4 Performance chip question MPG and HP chrome Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 18 02-08-2011 11:25 AM
Diesel Tunes Performance Chip knsram Dodge Ram General Discussion 5 02-04-2011 11:08 AM
Question on performance parts 2011 Dodge Ram R/T el RT7 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 01-25-2011 05:45 PM
Have a question about my superchips programmer OTwoRam Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 08-20-2009 11:16 PM
