Old 03-28-2011, 09:54 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Default High Beam issues
Ok, I thought it was the multi switch in the steering column, replaced that and I still have an issue, Here is the problem.
There are some aftermarket fog lamps wired into the factory fog lamps and they work when you pull the run light switch ( on the dash ) on at the first position, Then the second position turns on the headlights.
Now when you pull back on the directional lever to turn on the high beams, the switch clicks but as you release it the high beams dont stay on? I dont understand why but the passenger high does not work at that time?
When the fog lamps ( running lights ) are on both the high beams will flash with the lever, and when no lights are on both high beams will flash. But when the headlights are on, only the drivers side high beam will flash?
I am baffled with this, and I need to get the truck inspected soon so I can street it,,,, What do I do?
Thanks In Advance for any help.
Mike
Old 03-28-2011, 10:05 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Sorry to hear the multifunction switch didn't take care of the problem. I had an intermittent issue with my headlamp switch that would have the fogs turning off if I hit a bump on my 2006 RAM. Had the dash switch replaced and that fixed my problem.
Old 03-29-2011, 01:11 AM
sonocativo's Avatar
Rep:215
I might have to try that next....dash switch.
Mike
Old 03-29-2011, 02:37 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Check the ground wire on the passenger side headlight.
brad
Interested in one of my mods?
Old 03-29-2011, 12:46 PM
sonocativo's Avatar
Rep:215
Ground is good as the light works any other time...is there some sort of relay under the hood for the high beams? Everything in the fuse panel is good.
Mike
Old 03-29-2011, 11:58 PM
brad12kx's Avatar
Rep:2581
I do not have experience or wiring information on your model year, so am only applying general wiring experience. I recently had a similar issue with a 2006 Chevy van, and the culprit turned out to be a faulty ground wire connection right at the headlight bulb. In this case, the light on the affect side was 'slightly' dimmer than the properly working counterpart. Are your lights of equal brightness on each side when working?
brad
Old 03-30-2011, 10:30 AM
sonocativo's Avatar
Rep:215
Yes, equal brightness, just the highs flash when you pull the lever in all positions with the fogs on, with headlights on the passenger doesnt work and the highs wont stay on? I am dreading taking it in for repairs as money is really tight...
Mike
Old 03-30-2011, 10:50 AM
Rep:1890
I'd pull the headlamp plug loose and check the ground for continuity with a DVOM.
Old 03-30-2011, 03:03 PM
sonocativo's Avatar
Rep:215
Ok, I took a little video of what it does, as you can see the fog and aux. lamps run together ( wire tapped ) and they go off with the headlights on or flashing the high beams ( see both lights work at this time )
Then while headlights are on and you flash the high beams only the drivers work and the high beams will not stay on no matter what.... I looked, wiggled all the wiring with no luck of any shorts or anything, could it be the dash light switch? I heard on the 97 there were no headlight relays and everything ran from the headlight switch?? Thanks for any help and responses on this issue in advance. Great bunch here and a great atmosphere on the site !!!!
Mike
Old 03-30-2011, 03:12 PM
Rep:1890
Where's the video? The dash switch feeds power to low and high beam circuits from the same source, so I doubt that's it.
HID High Beam Flashing RamCaper 2010 Dodge Ram Forum 3 01-16-2011 11:34 PM
High beam lights messed up. sixwheeler Electrical 5 11-26-2010 12:59 PM
Tap KC Lite switch into high beam headlights? KirkCJohnston 2009 Dodge Ram Forum 11 04-28-2010 01:15 AM
2004 High Beam Wiring oh4ohyeah Electrical 6 04-06-2010 12:35 AM
No Low Beams - High Beam position gives Low Beams daveruybal Electrical 3 02-21-2010 06:31 PM
