Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 03-29-2011, 06:40 PM
jerbo jerbo is offline
Vehicle: 2005 dodge ram
Color: blue
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
jerbo is on a distinguished road
Default front hub assembly
hello all i am new to this site so i am hoping someone can tell me the best way to remove the front hub assembly on my 1 ton 4x4 dodge u joint r bad.
Old 03-29-2011, 07:42 PM
RamTech RamTech is online now
Rep:1845
A heavy duty hub puller, a BFH, and some blood, sweat, tears and swearing.
Old 05-06-2013, 03:31 AM
Pacheco911 Pacheco911 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Dark Green
Pacheco911 is on a distinguished road
Big hammer, pb plaster, and lots of flathead screwdrivers.
Old 05-06-2013, 11:08 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The one ton (95 if that's the one you're working on, this is the 1st gen section) should be held in with 4 bolts:
Remove the cotter pin and axle nut (1 1/6 nut I think or like 34mm)
Jack the truck up and take off the tire and caliper.
Remove the 4 bolts from the back of the hub and bearing.
Sometimes the bearing comes out with a few taps, sometimes it cost your first-born son.
After you get the bearing out the axle'l slide right out.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 07:14 PM
Question on front wheel bearing assembly. Beauacadian Suspension 1 03-04-2011 11:15 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 11:48 PM
New Guy here. . . .looking for front bumper assembly Buff Guy Newbie Checkin! 11 08-04-2010 05:36 AM
