Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 03-29-2011, 08:21 PM
pirayaman's Avatar
pirayaman pirayaman is offline
Vehicle: 1987 le250 power ram
Trim Level: fully loaded
Color: 2 tone red white
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Rep:25
pirayaman is on a distinguished road
Default trans burnt fluid problem
i have a 1987 ram le250 5.9l . when at stop sometimes my truck would seem out of gear id put foot on gas and it felt as if my trans was spooling up and then would slam and then would go . i changed fluid and filter . fluid was black . then the new fluid was fine and trans was without that spooling problem but within 5000 miles trans fluid is black again and trans starting to have that same spooling prob feels like its in neutral then slams into drive by itself thx in advance
Old 03-29-2011, 08:26 PM
Resident Technician
Rep:1915
I would expect the fluid to be black again because you left the majority of it in the trans when you serviced it. The only way to get it all is by flushing it through the cooler lines. Did you do a band adjustment while you were in there?
Old 03-30-2011, 06:29 AM
pirayaman's Avatar
Rep:25
no didnt do a band ajustment . i didnt have anything with me to keep the truck off the ground and the haynes manual says it needs to be to ajust
Old 03-30-2011, 07:56 AM
Resident Technician
Rep:1915
Say what? Off the ground to do a band adjustment, huh? That's a new one to me and I have to say that diminishes what little faith I had in Haynes.
Old 03-30-2011, 08:20 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
true that! maybe Haynes figures everyone has access to a lift....
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Trans fluid H2OJoe 5.9L V8 Specific Topics 1 03-15-2011 11:31 AM
Newbie here! 04 HEMI trans fluid smells burnt 04HEMIpower LD RAM - General Discussion 1 02-27-2011 06:43 PM
Trans problem 09m109r 2009 Dodge Ram Forum 7 02-02-2011 08:55 PM
Low Trans Fluid Burkdadhemi LD RAM - General Discussion 2 01-08-2011 09:21 PM
please help with trans problem sbsg2005 5.9L V8 Specific Topics 1 10-13-2010 10:42 PM
