Dreaded CLUNK... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-30-2011, 08:57 AM
RAMTIM23's Avatar
RAMTIM23 RAMTIM23 is offline
Vehicle: 2007 Dodge Ram, Big Horn, hemi
Trim Level: Big Horn SLT
RAMTIM23 is on a distinguished road
Default Dreaded CLUNK...
Hello,
Front end is clunking when I go over bumps. Truck is not under warranty, so wondering what best route would be to start?
Is a slipped belt common in wranglers? Moved the suspected tire to rear and wondering if this will do any damage?
RPM fluctuation? while going down the road I notice my RPM's move from 1800 to 2000/2100 even while in cruise. Normal? thoughts....
How do I know when truck goes from 8 to 4 cylinders?
Thanks for all help. Sorry for overload of questions. Just new to the RAM life and forum..
Old 03-30-2011, 10:12 AM
Resident Technician
Rep:1915
Clunking could be anything. Start by inspecting all steering and suspension joints.
Broken belts aren't uncommon in Wranglers and they're easily spotted. They will also cause a horrible vibration and a pull if on the steering axle.
Sounds like MDS operation to me.
You just have to listen for a change in engine sound.
Old 03-30-2011, 10:25 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Glad to have you here, great questions and it looks like Randy has hit the answers on the head, again. (that's why we respect him).
You'll enjoy the truck.
Old 04-14-2011, 11:16 PM
SCHNELL SCHNELL is offline
Vehicle: 2002 DODGE RAM 1500
Color: RED
SCHNELL is on a distinguished road
I got a clunk and its the control arms, old nasty bushings, so I'm just gonna change ball joints while I'm in there
Old 04-15-2011, 09:33 PM
esemans55 esemans55 is offline
Vehicle: 2011 Ram 2500 5.7 Hemi 4x4
Rep:32
esemans55 is on a distinguished road
my 03 1500 has a rattle somewhere in the rear , ever since I changed my shocks I hit rough road area in town 25 30 mph I hear rattling noise . HELP
Old 04-21-2011, 03:19 PM
matt99 matt99 is offline
Rep:20
matt99 is on a distinguished road
could be anything from wheel bearing, ball joint, control arm bushings, or shocks.
Shocks are the easiest to check. push down on your bumper on either side, if the truck bounces over and over its probably them.
Ball joints can be checked by lifting your front end and pushing on your wheel 3,6,9,and 12. any play?
Control arm bushings are harder to check but lifting your suspension from the spindle side you might see some play
wheel bearings usually give more of a squeak or rattle/grind
[IMG]http://i294.photobucket.com/albums/mm110/swollguy99/1282248743-1.jpg[/IMG]
Murdered
Old 04-23-2011, 08:48 AM
GeorgeofGeorgia GeorgeofGeorgia is offline
Vehicle: 2003 1500 QC 4x4 5.7
GeorgeofGeorgia is on a distinguished road
I would take a close look at the anti-sway bar bushings where they mount to the frame/body. They could be worn allowing a deeper thud/clunk sound over bumps.
I'm sure there's a write-up on proper testing of these somewhere on the internet.
Old 06-14-2011, 08:36 AM
Dingo Dingo is offline
Vehicle: 2003 Dodge Ram 1500
Rep:22
Dingo is on a distinguished road
I know I'm coming in late to this post but I have the same clunking in my front end. It is the sway bar end ling bushings. How I figured it out with minimal work is I pushed side to side on the tires to shake the truck and when I heard the clunking, I would touch each of the components under there. I felt a thud on the sway bar every time I heard the clunk.
04 1500 4x4 frontend clunk Pjw350 Suspension 1 12-27-2010 11:41 PM
Transmission clunk?? zobius 5.7L (345 cu in) HEMI V8 Specific Topics 6 10-29-2010 07:08 PM
slight clunk feeling UnLiMiTeD 2010 Dodge Ram Forum 25 10-17-2010 11:53 AM
Transmission delayed clunk andyjs3589 Body & Interior 6 10-15-2010 10:23 PM
Steering Clunk Quiet Lunatic Suspension 2 09-08-2010 11:43 PM
