P0132 and P0138, Excessive Fuel Consumption... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-30-2011, 07:13 PM
uptheirons uptheirons is offline
Vehicle: 2003 Dodge Ram
Color: Tan
uptheirons is on a distinguished road
Default P0132 and P0138, Excessive Fuel Consumption...
soooo, i keep getting the codes P0132 and P0138, which as far as i;ve found is High Voltages at the O2 Sensors, and Excessive gas Consumption, and i mean horrible, like 10-12 MPG on the highway, and as low as 4-5MPG in the city... I have replaced both o2 sensors already, but the codes keep coming back, kinda stuck now.
anyone had this problem, it also seems to run a it rougher than it did before, sometimes surges a bit when i'm slowing down.
keeps throwing the same codes out, sometimes throws out P0171, which as far as i've found is a "lean air/fuel mixture".
Any suggestions from anyone?
Thanks!
Old 03-31-2011, 06:16 PM
Either you have an intake manifold leak or some leaky injectors. But since you got the lean condition code, I suspect an intake air leak.
Good luck!
CEL CODES: P0132 and p0138 HELP!!!! RocKstArDoDge 5.2L V8 Specific Topics 9 03-14-2010 02:38 PM
