hard to get key out of ign. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 03-30-2011, 11:16 PM
sullivanj04 sullivanj04 is offline
Vehicle: 1997 dodge ram 1500
sullivanj04 is on a distinguished road
Default hard to get key out of ign.
so in order to get the key out or in you have to pull up on the shifter that and the gear selector on the dash doesnt line up, is there a way to adjust any of this?
thanks
Old 03-31-2011, 12:40 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
I don't think there is, most likely you will have to replace the column shifter.
Old 03-31-2011, 12:46 AM
Rep:2954
i think its only a simple adjustment
sensor doesn't think its all the way in the park position
Old 03-31-2011, 03:37 PM
I believe you can adjust the shifter linkage to get things to line up.
Old 10-02-2011, 09:02 PM
southbronxems southbronxems is offline
Vehicle: 1994 Dodge Ram 1500
Color: Dark Blue
southbronxems is on a distinguished road
Try a new key. Mine does that sometimes with the old key.
Old 10-05-2011, 06:45 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
sounds like the shifter linkage is out of whack, have someone to get in the truck and puch the gear selector up into park while you get under and loosen the nut on the bracket at the transmission, the rod will slide a little if out of whack into the correct position on its own as the shifter is being pushed on, tighten the nut back and check to see if it corrected it. It can get knocked out of whack if something on the road hits the rods as well as off roading due to the had jarring, also slamming it into park when mad as well as forcing it out of park on hills. Had several cars do this to me in the past. Hope this helps.
I Am Groot !
Uconnect Hard Drive Help mattluchini 2010 Dodge Ram Forum 8 03-28-2015 05:51 PM
Having a hard time finding one BCEAGLES LD RAM - General Discussion 4 03-03-2011 07:11 PM
Using ext hard drive to transfer music from Itune to truck cgayheartjr Newbie Checkin! 13 02-15-2011 06:06 PM
RAM-1500 Radio replacement gvangerven 2009 Dodge Ram Forum 5 01-26-2011 02:29 PM
2009 Factory Radio Guide RamTech Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 12-21-2009 03:55 PM
