tonneaucovered.com
Old 03-31-2011, 09:44 AM
Reed44 Reed44 is offline
Vehicle: 2000 Dodge Ram ext.cab 4x4 5.9
Color: dark green
Reed44 is on a distinguished road
Default trans shifting weird
well long story short, i went on a trip and lost overdrive and drove the whole way with out it. brought it back home let it sit for awhile and now it will shift decent when cold but not at all when warm. i took it to a trans shop and they said there was nothing wrong and they did some reset thing which i dont believe but it lasted 4 days after that then back to the normal problems. second will hang for awhile then shift and it dont like going into over drive sometimes and when you come to a stop it wont downshift all the way and sometimes it will take off in second, also when it gets real warm it will just go into a neutral and you cant go anywhere. when its cold though its not to bad. im pretty sure the trans is gone but i wanted to ask you guys and see what you said. could the check ball be a problem causing this?
Old 03-31-2011, 08:18 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
there are a hand full of sensors. govenor pressure solenoid and switch ,overdrive sensor they are inside the pan . search govenor pressure solenoid in the thread search theres s link. hopefully its something stupid and not a full rebuild good luck!
-PAT-
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 09:49 PM
$3,500+ in trans repairs,etc still no fix HELP! rcs4787 5.2L V8 Specific Topics 5 11-17-2010 02:48 PM
Possibly need new trans... IntenseDakota 5.9L V8 Specific Topics 5 09-27-2010 07:48 AM
same trans shifting and Heatercore? maniac 5.9L V8 Specific Topics 4 04-03-2010 04:24 AM
96 trans shifting after rebuild mdbasser 5.9L V8 Specific Topics 4 10-02-2009 11:10 PM
