Old 03-31-2011, 02:50 PM
hangerbum hangerbum is offline
Vehicle: 1999 Ram 2500 Diesel 2wd
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
hangerbum is on a distinguished road
Default Ball Joint Replacement Questions - 2wd 2500
I am looking for advice on how to replace the ball joints on a 1999 2wd 2500 diesel. Looking through the factory service manual. It only describes how check the b-joints and how to R&R the control arms. There is nothing about how to replace the ball joints. I have found a lot of info applicabe to 4x4's but haven't seen anything how to replace the b-joints on the 2wd 2500. Any advice/instructions is appreciated.
Old 03-31-2011, 10:27 PM
94ram1500's Avatar
94ram1500 94ram1500 is offline
Vehicle: 1994 Dodge Ram
Trim Level: SLT Laramie
Color: Green
Rep:139
94ram1500 will become famous soon enough94ram1500 will become famous soon enough
I'm not sure how much different the 2500 is from the 1500 but I used this tool to replace both upper and lower ball joints on mine. The original lowers I think had a small spot weld that you will have to grind off but other than that, they aren't that hard to do. It just takes a little patience.
Good Luck,
Ed
http://www.toolsource.com/ball-joint...evi3isp9dqdu20
Can someone please tell me, why common sense is so uncommon these days??
Old 04-07-2011, 10:32 PM
wpari798 wpari798 is offline
Vehicle: 1995 Dodge Ram
Color: silver
wpari798 is on a distinguished road
If your still trying to do this...Try YouTube. When I was replacing my b-joints I watched a guy replace the ball joints on a 99 Dodge Ram 1500. Im not certain but I dont think there is much difference from the 1500 or 2500. Look at your 2500's suspension then look at your example. Pull up manual pics from google. That help me. Basically need a heavy duty C-clamp to push the ball joint out (you can rent one from autozone), new ball joints, grease/gun for new joints and BFH to wack the crap out of the old ball joint if you cant get it to push out. Jack up your truck, take off the tire and you can remove the knuckle to make it easier for yourself.
Ball Joint Replacement nocoborn Suspension 9 03-03-2011 06:36 PM
question on Ball Joints JLash87 Suspension 9 02-15-2011 12:02 AM
Ball Joint Replacement - What Kind and How Hard? doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-11-2011 07:34 PM
Front End Replacement Parts Questions thardy3 Suspension 1 12-28-2010 10:36 PM
Lower ball joint falling out 98 ram1500 blodge5.2 Suspension 1 10-06-2010 07:47 AM
