Aux Battery - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 03-31-2011, 10:38 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
Default Aux Battery
I'm interested in installing an auxiliary battery under the hood on my 09 1500. I had one in my 97 where I bought the second battery tray for a diesel from the dealer, and it bolted on and made the install very easy. Looking under the hood on my 09, and the intake plumbing is taking up most of the space on the right side inner fender leaving almost no room.
Does anyone have any suggestions on placement or a way to relocate the intake plumbing to provide the room?
Thanks!
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 04-01-2011, 11:48 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
A plastic RV/Boat battery box in the bed, or a fabricated metal box (some offroad places may have this) bolted to the frame might do the trick... If you don't mind me asking, what is your reason for needing an aux battery? Other suggestions or options might come along if the reason is known.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 04-02-2011, 12:23 AM
viper19JN's Avatar
viper19JN viper19JN is offline
Vehicle: 2009 ram 1500 quad cab
Color: mineral gray
Rep:30
viper19JN is on a distinguished road
a remote cai and the diesel mount.
or...
I built a mounting bracket under the truck between the frame rails for a battery box it worked pretty good if you want I could get a pic for you
I installed mine so I can disconect it from the main truck battery and run a power inverter without draining my starting battery and my amp is direct wired to it as well
Old 04-02-2011, 01:40 PM
astroman54's Avatar
Rep:52
No problem in asking. I go to remote sites and use the truck to power my telescope and it's accessories. After one rather late night viewing with my old truck, my battery was dead enough not to start it. So that's when I chose to put an auxilary battery in it and want to update the new truck with one as well.
I'm open to all suggestions and appreciate pictures if you have them of your solutions.
Thanks,
Andy
Andy
Old 04-03-2011, 12:48 AM
viper19JN's Avatar
Color: mineral gray
Rep:30
no problem these are crappy but you should get the point
now you have brake lines and fuel lines on the inside of the frame rail so it has to mount on the outside or at least have spacers too clear the lines but there is plenty of room under there for a battery I will redo mine later with a metal sealed box and a better battery but for now this works
down falls: not easy access, deep water would be an issue,
Old 04-03-2011, 01:51 AM
Rep:2964
easiest way would be to move the air filter box & put the battery in its place
several CAI products would make the air box movable
Battery drain jdjackson Electrical 5 04-23-2017 01:55 PM
2008 Dodge Ram 1500 - battery chapala01 Electrical 11 12-10-2015 12:19 AM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Battery Isolator WesGPS Electrical 2 04-02-2011 01:43 PM
Battery Won't Stay Charged! taycom Electrical 8 12-22-2010 10:15 AM
