Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 04-01-2011, 12:57 AM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
Default brake pads
want to change my front brake pads on my 06 1500 mega cab, have the pads, but im wondering if i need any speacial tools to get the job done or anything i should know before i dive into this.
also is it ok to just push the piston on the caliper back in with a c-clamp ?
"I'm your huckleberry" (Doc Holiday)
Old 04-01-2011, 01:23 AM
jgshannon jgshannon is offline
Vehicle: 2005 Dodge Ram 1500
jgshannon is on a distinguished road
I changed mine a year ago in my '05 and I'm pretty sure all you need is some basic hand tools (socket set, open end wrench). I just used a pair of ChannelLocks and opened the bleeder to push the piston back on mine. Oh, and an extra set of hands to bleed em
Old 04-04-2011, 05:27 AM
67Polara's Avatar
Trim Level: sport
Rep:77
do i have to bleed the brakes or is that that only way it can be done ?
Old 04-08-2011, 11:11 PM
Camoray Camoray is offline
Vehicle: 2000 Dodge Ram 1500 Quad Cab
Trim Level: Laramie SLT
Color: Dark Blue Metallic
Camoray is on a distinguished road
You shouldn't have to bleed them unless you open the line for
some reason and get air in the line......Just use a large C clamp
or a large pair if adjustables to compress the piston....place one
of the old pads over the piston and compress against it with the
C clamp.....you might first want to suck out a small amount of brake
fluid from the reservoir (1-2 ozs) because fluid will back up into the
reservoir when you compress the wheel caliper cylinders.....also...
Don't let the caliper hang on the brake line after removing....hang it with wire or set in on a 5 gal. bucket to take the weight......
ps....check out "You Tube" for brake pad replacement.....really not that
hard a job....just follow directions and take your time.
Old 04-10-2011, 05:58 AM
67Polara's Avatar
Trim Level: sport
Rep:77
Thanks guys, i'm very leary of doing things to my ram. first newer vehicle ive owned.
Front Brake Pads Will 3500's Fit 1500's? ACannon 4.7L PowerTech V8 Specific Topics 2 12-31-2010 08:43 PM
brake pads - thoughts Cowboy 2009 Dodge Ram Forum 24 05-17-2010 06:37 PM
Brake Pads dodgehemi Brakes 7 04-07-2010 12:10 AM
Spark plugs and brake pads for 5.7 hemi daveredneck 5.7L V8 Specific Topics 7 03-11-2010 05:39 PM
Brake pads part number? azaelx Brakes 4 12-02-2009 05:13 PM
