Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 04-01-2011, 09:38 AM
Ramher07's Avatar
Ramher07 Ramher07 is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Trim Level: Thunderroad
Color: Gold
Ramher07 is on a distinguished road
Default blend door woes
Hello all,
I have a 2007 Ram 1500 5.7L. My heat is coming out of the defrost vent. The selector will change it to mid level vents, but will not direct to floor vents. Any advice for a fix?
Old 04-14-2011, 12:49 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Dealer scan tool can recalibrate it, but it might be physically broken...
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 06-12-2012, 10:32 AM
don482005 don482005 is offline
Vehicle: 2012 Outdoorsman
Color: True Blue Pearlcoat/Mineral Gray Met. Clear Coat
don482005 is on a distinguished road
had the same problem on my 2002 1500 when to heater treater and got the mode 1 door when we tore the dash apart the door was fine.....that was 115 bucks didnt replace the door ordered a mode 1 door actuator....35 new from dodge replaced it still wouldnt change position maybe sometime it would but then it wouldnt so i ordered a new dash switch well used
one off ebay i hope this works.......
Old 06-14-2012, 09:41 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I realize this is an older thread but here's an answer for ya anyway.
Sounds like your problem is very likely mode door 2....not mode door 1. MD1 simply diverts air from the main front vents to the secondary part of the system. MD2 is the one that decides whether the air goes up to the defrost or down to your cold toes. MD2 failure is common on these trucks and unfortunately is the most difficult to fix. Heatertreater does make a kit but a large part of the dash still has to be removed to access MD2. Per Heatertreater....."Most people choose to wear two pairs of socks than to replace MD2."
Old 06-14-2012, 11:33 PM
it was the switch the old one wasnt working the new one goes to all the different positions
Heater Blend door help 03Cactus Heating & Cooling 4 11-14-2012 10:30 PM
HVAC blend door acting goofy txhemi Heating & Cooling 1 01-24-2011 07:10 PM
Heat problem and door blend Dtimekw Heating & Cooling 7 12-08-2010 09:22 PM
Blend door motor won't stop going Quiet Lunatic Heating & Cooling 7 11-28-2010 02:02 PM
Winter blend gas, How far south? GPSHSLAX Dodge Ram General Discussion 6 02-12-2010 12:38 PM
