1999 5.9L (gas) - No power under 3500 rpm's - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 04-01-2011, 09:44 AM
IntenseDakota IntenseDakota is offline
Vehicle: 1999 Dodge Ram QC 4x4
IntenseDakota is on a distinguished road
Default 1999 5.9L (gas) - No power under 3500 rpm's
So, as the title states, I have a 1999 Dodge Ram quad cab 4x4 sport. When I am getting on a highway, or leaving a stoplight on a road where the speed limit is 55mph, it takes forever to get up to 30-35mph. Basically what happens is no matter how far I press the gas pedal down, it slowly increases speed. Once I hit about 3500 rpms, it takes off like a whole different truck. 3500 through 5000 rpms, it has power to spare. The only other real symptom is that when I do the above and the engine is cold (running for less than a minute or two when leaving work) the truck seems to "really bog" until I let my foot off the gas for second. It never shudders or stalls or anything though. It is wasnt a cable driven throttle body, I would almost think the truck just wasnt getting the throttle I was giving it untill 3500 rpms. There is a hill that I go up (about 25-30 degrees up) and from a stop at the bottom, I cannot get past 2500-3000 rpms, unless I mash the gas pedal and make it down shift to or (stay in) 1st.
It does have a slight shake at idle, nothing more than what I would consider normal though, I mean, it's not new, and it aint a cadilac. Also, once the engine is warmed up, the oil psi is around 60'ish while driving, but will drop to just under 40 at idle. It has never dropped below about 30-35 though.
I replaced the transmission and torque converter late last year because of some noise, but this problem has been there since before that.
I just picked up a triple pillar pod along with Trans Temp, Fuel Pressure, and Vacuum gagues which I will hopefully have in this weekend.
I am thinking it may be the fuel filter, but I don't want to drop the tank and everything if I don't have to.
Old 04-01-2011, 04:03 PM
ARMedNBangin's Avatar
ARMedNBangin ARMedNBangin is offline
Vehicle: 1999 Dodge Ram 4x4
Trim Level: Laramie slt
Color: Black/Grey
Rep:16
ARMedNBangin is on a distinguished road
I hope you find the solution to your problem. I have the exact truck, so I'll be watching this thread.
Aaron Roy Matherne--99 Ram 1500 4x4 5.9L Laramie
I got 99 problems but my truck ain't one.
1997 1500 4x4 5.9L Loss of Power Robb 5.9L V8 Specific Topics 5 08-15-2011 03:01 PM
Trade 05' Ram Hemi 1500 4x4 for 07' Ram 3500 5.9L Hemiboy LD RAM - General Discussion 1 02-01-2011 07:08 PM
my 99' 5.9l has a huge loss of power hacksaw629 Newbie Checkin! 10 08-13-2010 03:56 PM
Coolant loss in 1999 Dodge Diesel 3500 dually kebro004 Cummins Diesel Specific Topics 3 07-13-2010 11:19 PM
98 Dodge 1500 4x4 5.9L / No Power to A/C Clutch fade2zero Electrical 2 01-03-2010 11:30 PM
