Old 04-01-2011, 12:21 PM
D5UPE's Avatar
D5UPE D5UPE is offline
Vehicle: 1998 1500 LaramieSLT Dodge Ram
Color: red
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
D5UPE is on a distinguished road
Default Bearings 2wd Front Question.
2nd Gen 2wd SLT Laramie 1500 Wheel bearings.
Has anyone a part number and price?
Or better still the bearing size, type and shell number So I can try matching
from local bearing supplier?
I'm in England and parts are hard to source, or very expensive and buying from USA/Canada is becoming a nightmare. Customs duty is just daylight robbery.
Has anyone done a 2wd bearing replacement job, and how tricky is it?
Cheers David.
Old 04-05-2011, 02:28 PM
JrBlanchard24's Avatar
JrBlanchard24 JrBlanchard24 is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT LARAMIE
Color: PFA Driftwood Satin
JrBlanchard24 is on a distinguished road
Default In the same boat...
Im in the same boat as you are man. My right front was chattering over 40mph, now the whole wheel is vibrating like its gunna come off...
My buddy is going to throw it in tomorrow.
All i can tell ya is this:
If you have 2 Wheel ABS, the price each is $160.00....
If you have 4 Wheel ABS, the price each is $320.00....
I have 2 Wheel ABS, so its the cheaper route for me this time... But I'm only doing the passenger side...
Are you supposed to change them both or just one at a time???? is my question for our DODGE buddys!!!
Old 04-12-2011, 08:47 AM
D5UPE's Avatar
Color: red
I got my bearings sent in the post. Now fitted shells and seals. Both wheels
2 hour job. What a difference they make on noise. There's none.
If any of you do the front 2w/d bearings which are only tapered bearings.
Do the shells and remove any old grease. The old grease will gave bits of old bearing and cage in it and wont do your fresh new bearings any good.
And will fail so much quicker than doing the job right.
I'm giving the truck a couple of days ride before nipping the axle nut up a quarter turn again.
The bedding in should be good by then.
When I get back in the garage I'll post the seal and bearing numbers for future ref.
coil spring question raymegacab Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 10-27-2010 02:01 AM
Front Axle Question tomcatg Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 10-25-2010 09:27 PM
New Member With Front Bumper Question Erniedytn Newbie Checkin! 15 10-12-2010 03:11 AM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 09:26 PM
the front end or back end? that is the question! zacotaco Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 9 12-27-2008 05:12 PM
