Old 04-01-2011, 11:38 AM
Adam302 Adam302 is offline
Vehicle: 2011 dodge ram
Trim Level: 1500 Big horn
Adam302 is on a distinguished road
Default need help
2.5 level kit installed. Still need inch to make look right. What else can I do that wont break bank?
Old 04-01-2011, 12:48 PM
JHamilton's Avatar
JHamilton JHamilton is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Cherry
Rep:92
JHamilton will become famous soon enough
Without a lift, nothing. What kit did you use? No kit will be perfectly level as the back should sit a little higher.
I'm a failure by standards I reject anyway.
Old 04-01-2011, 01:20 PM
Daystar. Ended up two inch difference
Old 04-01-2011, 01:35 PM
JHamilton's Avatar
Color: Deep Cherry
Rep:92
Well people have said that the Daystar kit does not raise a full 2.5" (depending on the truck), but there is only a 3.25" difference in my truck stock so that doesn't sound right.
What was the height of the spacer?
Can we see a picture?
Old 04-01-2011, 01:59 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
I leveled mine with bilstein 5100 shocks. I set it on the 2 highest level and I am almost perfectly level. The highest setting is 2.8 inches of lift and that put it 4/16 of an inch higher than the back stock height if that's enough awesome. If not I see a lift kit in your future.
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 04-01-2011, 02:51 PM
How much were the 5100. I should have went that route from the get go. Easy Install?
Old 04-01-2011, 02:57 PM
I only have box I had it installed while I was at work. The kit says 2.5 inch
Old 04-02-2011, 04:15 AM
E.L.D. 44's Avatar
Rep:388
I paid 214 for the front shocks. I didn't do it myself. My dealership charges me half normal labor rate to do all my work there so I just had them do it. There are directions in the box for which setting to use. If you are buying the 5100s for the back too I would use the highest setting. You will be really impressed with the ride quality. It's the best mod I've done so far!
MY MOD THREAD
Old 04-02-2011, 06:26 AM
Where did you buy them at
Old 04-02-2011, 12:53 PM
E.L.D. 44's Avatar
Rep:388
I got them from 4 wheel parts and picked them up at my local store. On the 2nd highest setting the front is 5/16 of an inch lower than the back and on the highest setting it's 3/16 higher. Sounds like you need the highest setting and the rears to achieve what you are wanting. If that doesn't get it lift kit is your only option. The ride quality is excellent and no death wobble. Like I said it's the best thing I've done so far
MY MOD THREAD
