Old 04-01-2011, 12:33 PM
rgnbull1227's Avatar
rgnbull1227 rgnbull1227 is offline
Vehicle: 2006 Dodge Ram Mega
Rep:104
rgnbull1227 will become famous soon enoughrgnbull1227 will become famous soon enough
Default Anyone else with a 6" lift blinding people?
I constantly get people hitting me with the brights thinking my are on. Any way to drop the aim of the low beams?
Old 04-01-2011, 12:41 PM
mattee's Avatar
mattee mattee is offline
Vehicle: 2002 1500 Ram QC 4x4
Rep:13
mattee is on a distinguished road
it's tough with that much lift but if you look straight into the headlight(with it off), you will see adjusting screws, 1 for vertical and 1 for horizontal. to do it properly though you shuold have an alignment rig, however if pull up to a door or wall and mark your beams on it you can lower them and watch how far you are turning them down.
Old 04-01-2011, 12:42 PM
mattee's Avatar
Rep:13
by the way, kick a** looking truck!
Old 04-01-2011, 12:45 PM
Rep:104
Thanks. Gotta lower these beams a little. As the people pass, I can see right into the front seat and they are getting blinded. Damn guys and their lifter truck!
Old 04-01-2011, 01:16 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
i can imagine. i leveled mine and was getting brighted.
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 04-01-2011, 01:49 PM
Rep:104
Thanks. Gotta lower these beams a little. As the people pass, I can see right into the front seat and they are getting blinded. Damn guys and their lifted truck!
Old 04-01-2011, 03:18 PM
mattee's Avatar
Rep:13
Sorry, I lied a little. With your model truck there is only a vertical adjustment screw, no horizontal. it is located on the inboard side of the headlight assembly.
Old 04-02-2011, 11:23 PM
wigbill98 wigbill98 is offline
Vehicle: 2009 Dodge Ram
Rep:44
wigbill98 is on a distinguished road
Pop your hood and look on your fender, you should see 2 holes and one of them has a arrow pointing to it, you can look down that hole and see the screw, I am not sure if its the same as my 09 but you can either use a 7mm socket or a T20 torx bit will work.
I did this with my projectors like 5 times to get it right where I want it!
-Will
Mods = Retro-Fit Projectors & HID's with painted housing, Welded Muffler, VHT Nite-shades Chrome License Plate Frame...OH YEA!
6" Lift Kit for '08 Ram 1500 that bolts on JRF3282 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 05-08-2011 12:33 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
How to Do a Lift Properly RootBeer Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 07-29-2010 12:50 PM
37's and 6" lift?? wldcts3 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 17 03-29-2010 09:04 PM
6" lift, 35" tires.. Should i? JoeJoe09 Dodge Ram Wheels And Tires 6 02-05-2010 10:43 PM
