Old 04-01-2011, 02:51 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Default Fluctuating idle and disappearing ATF+4
So my truck started doing a new piss me off the other day. In hindsight this has been going on since I cleaned the throttle body a few months back, but is now getting worse. Just after cleaning the throttle body, on cruise at 70 mph, I can feel the idle play back and forth every couple seconds. It will do this for a while and then stop.
Within the past week, when I come to a stop or put it in park idle will go down to 500 or so (normal), but it will then go up to 1200 suddenly, then back down to 400 then back up to 1500 (not normal), it will do this for a few seconds then stop. I have no codes or other tells.
I searched and only came up with problems with the engine dying. Someone suggested it could be my torque converter continuosly locking and unlocking. I checked the fluid cold, showed normal. I checked the fluid hot and it was low 3/4 of a quart or so. I topped up and now truck runs like normal. However, now that I was paying attention, I noticed something I had gotten used, but it did do since I bought it. When I come to a stop the RPM will dip to 3-400 and then level off at 500. I can live with that. I realize that a 4wd flat filter could have been put in there and they are shorter then the 2wd filter and when it gets low the truck could be sucking air causing it to act weird. It is due to be changed again in 2k miles so I will see then.
My concern is where is my transmission fluid going? I had the fluid and filters changed just after buying the truck and a few months after that I was down a half quart or so. I just figured it was from topping off when I had the filters changed and the truck not ever being driven. But now it was down another 3/4 quart. Im wondering where it could be going as I witness no drips on the ground whatsoever. I notice ANYTHING my truck drips as I have a 4.7 liter and blown HG is always at the back of my mind so I am always looking at the exhaust (dumped) and I notice nothing. The closest I can come is the transmission tail shaft seal is seeping, I noticed this when I changed my UV joints but I cant be sure that just wasnt from me bumping it when I took the driveshaft down. Any ideas?
Sure it'll suck, but it'll make you a man
Old 04-04-2011, 12:28 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Oh yeah, I level the truck between last time I checked it too. That in itself might explain something. Thanks for all the ideas guys.
Old 04-04-2011, 12:40 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Are you checking the trans fluid level in neutral?
Since the idle problem started after cleaning the throttle body, I am betting you sprayed either the IAC (idle air conrol) or the throttle position sensor directly with throttle body cleaner. I read somewhere that the liquid gets past the seal and ruins the sensor.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 04-04-2011, 01:14 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
That may have happened, but it went away after a few days until this past week. It doesnt do it since I added the transmission fluid that was low. When I checked the transmission fluid the truck had been drivin 10 miles or so, and was at operating temp in neutral on level ground. I also shifted between all the gears first for a few seconds.
I also rechecked the tailshaft seal and it is damp as it had been but didnt look like any kind of leaking was taking place. I brought up the 3" level because I thought about it when checking my oil yesterday. Since I leveled it my engine oil marks higher on the dipstick with the usual amount of oil in it. I noted this at first change after the level and also noticed a change in the coolant level in the bottle when I leveled it. Thats what made me wonder if that would have any effect on transmission fluid as well. Makes sense to me anyway.
Old 04-04-2011, 08:26 PM
latitud's Avatar
Rep:71
I am betting the trans fluid seeming to make things better is just a coincidence. Unhook the battery for about 5 min. turn your lights on after unhooking the battery to dissipate any remaining power. Hook it back up and this will make you TPS recalibrate itself...not sure on 2002 but you may have to turn the key to on - dont start - and push the throttle all the way down and then release.
As for the IAC, remove it and clean the tapered end really good and also the seat in the throttle body..remove all the carbon. The throttle body gasket is reusable, but you could have damaged it and it is simply sucking vacuum past the seal.
Old 04-05-2011, 08:16 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
I will do the reset today, and remove the TB again this weekend to check on that seal.
Old 04-11-2011, 01:11 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Update. Problem was the TPS. Runs 100% better now, even cured a couple other peculiar behaviors that have been present for a little while.
Old 04-11-2011, 01:15 PM
latitud's Avatar
Rep:71
Congrats on the fix.
Old 04-11-2011, 02:35 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Thanks. Makes a big difference for $30 and 20 minutes.
