Old 04-01-2011, 02:52 PM
snowman44077's Avatar
snowman44077 snowman44077 is offline
Vehicle: 2012 Ram 1500 Sport 4x4 QC
Color: Cherry Red
Rep:41
snowman44077 is on a distinguished road
Send a message via AIM to snowman44077 Send a message via Yahoo to snowman44077
Exclamation Heads up on your electrical system...
Some of you may know this, and some not. I've been in the car business for 12 years and this is the first I've heard of it...
Your 2006 and up Rams have an ECM (Engine Control Module). This replaces almost all of your fused circuits and relays with a computer. This is great for more accurate warning lights and helping the systems talk to one another. The system has integrated relays. That's to say, relays that are hooked to breakers and any variance in power above or below the set tolerance can trip the breaker. When this happens, the computer resets it and goes about it's business.
Where it gets ugly is if you put too much load (example: adding extra reverse lights that are wired directly into your factory back up lights, like, ahem, I may have done). These will trip the breaker in the ECM, it gets reset and works again. UP TO 250 TIMES. Once you do it more than 250 times, the circuit is disabled, and you must take it to the dealer to be reset. They can reset it up to five times. After that, you just bought yourself a new ECM to the tune of $1,200. Congratulations.
What caused all this for me was a great little product called WhiteNight http://www.whitenight.com/ that was wired in not so great by yours truly. When the truck was put in reverse, the light would come on after about a one second delay. Turns out, the delay was when the ECM was reseting the breaker and turning the circuit back on. Then one day (apparently after backing up 250 times), I lost my reverse lights entirely. Disconnected it, went to the dealer (my work), got it reset, and wired it in correctly using the provided relay that I ignored before.
Many of you may already know this. Some of you may not. I just wanted to document it so when some schmuck like me decides to search the forum for info on it, it's here.
Cheers!
Snowman
Snowman44077
-2012 Ram 1500 Sport Hemi 4x4 Quad Cab 6.5 Box - Unstock Zee Truck...
Old 04-01-2011, 03:05 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Very interesting, thank you. Is there any way to tell when I am putting on too much of a load? I have a reverse led bar for example installed, and I have the reverse wired to the left taillight reverse. And the right and left blinkers are on wires further down under the bed somewhere, I didn't directly connect them on the tail lights. They work fine.
Would a voltage being too high on a passenger side headlamp cause the ECM to reset itself?
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 04-01-2011, 03:59 PM
Color: Cherry Red
Rep:41
Good question. When I came in my service writer printed an electrical chart that outlined the tolerances. This is also why LEDs without anything to weight the load of the draw can cause faulty turn signals in Dodges.
For the side to side question; I believe I remember the left and right sides of the truck separated for headlamps and parking lights/turn signals. That could be your problem. Like I said before, the delay for about 1/2 to 3/4 of a second from power on to actual illumination could be a telltale sign of this. Hope you get it worked out. Ask your Dodge dealer for some wiring diagrams!
Snowman44077
Old 04-01-2011, 08:56 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
I gotta wonder what this means for HID Headlight kit owners...
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 04-01-2011, 09:37 PM
Rep:1885
Um...ok. I've never heard of any of that before. There aren't any modules in the gas burning Rams called the ECM, only the diesels. The PCM is the engine controller and the module you're referring to is the TIPMCGW. Over amping a circuit will trip any internal breakers but underamping won't.
Old 04-03-2011, 12:53 AM
sullivan's Avatar
Rep:202
Good to hear, thanks.
Old 04-03-2011, 01:01 PM
Color: Cherry Red
Rep:41
My only personal experience is with this truck. I've sold them for years, but DCX doesn't give the retail staff that sort of knowledge.
I love my truck, just have to learn how to live with it sometimes!
Snowman44077
Old 04-03-2011, 03:34 PM
dillon00's Avatar
dillon00 dillon00 is offline
Vehicle: 2006 Ram 1500 TRX-4 5.7HEMI
Trim Level: SLT/TRX-4
Color: Mineral Gray
Rep:25
dillon00 is on a distinguished road
so did you have any problems after you wired it in correctly using the relay? or with what ramtech said, would this even be an issue on a gasser?
Old 04-04-2011, 12:15 PM
Color: Cherry Red
Rep:41
Nope, she runs like a champ now! As for gas vs. diesel, I'm not aware of the differences.
BY THE WAY: I HAVE A SECOND SET OF THESE LIGHTS BRAND NEW IN THE BOX. THEY RETAIL FOR ABOUT $75 SHIPPED. MAKE ME AN OFFER ON THEM IF ANYONE IS INTERESTED...
Snowman44077
Old 04-12-2011, 04:33 PM
Color: Cherry Red
Rep:41
Still have my rear lights available. I'd take $50 from someone on here!
Snowman44077
breaker, ecm, lights, reverse, wiring
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
2008 Ram 1500 QC - System Planning Questions vabch22 Custom Dodge Ram Interior Modifications - Custom Audio / Video 12 11-05-2010 01:20 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
In need of new cylinder heads dacota1950 Dodge Ram General Discussion 1 12-12-2008 12:38 AM
