Old 04-01-2011, 06:43 PM
ohmega07's Avatar
ohmega07 ohmega07 is offline
Vehicle: 07 Mega Cab
Trim Level: laramie
Rep:183
ohmega07 has a spectacular aura aboutohmega07 has a spectacular aura about
Default smallest size wheel?
i have been trying to find a definitive answer for the smallest size wheel diameter that i can fit on my 07 dodge ram 2500 mega cab? It came stock with the 8lug 17" factory wheels, but i want to get a set of spares for offroad use, any help would be appreciated
"If I was worried about gas mileage, I would have bought a Kia"
Old 04-01-2011, 07:38 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
17 inch are the smallest any smaller wont go on because of brake clearance
Old 04-01-2011, 08:17 PM
I know that 2nd generation rams came with 16's but the brakes were smaller in the front and the rears had drums. I don't think any of those would fit your truck.
Maybe you can measure the offset and backspacing of your stock wheels. Here's the specs on the smaller wheels:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
Now, as a comparison, here's the specs on the 17" wheel for the 2000 - 2003 trucks that had rear disc brakes:
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Lug Pattern: 5 on 5 1/2
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
You can see there are a couple of key dimensional differences between the 15" and the 17" to accommodate the larger brakes.
I think a 15" wheel with the same backspace & offset specs as the 17" wheel above would work but finding them is gonna be problematic. I don't know that they exist!
Good luck.
Old 04-01-2011, 10:07 PM
ohmega07's Avatar
Trim Level: laramie
Rep:183
ok, thanks for the heads up, i wasnt sure and seems like larger offroad tires are cheaper with a 15-16 wheel.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Wheel size? Spartan7G09 Dodge Ram 4x4 - Offroad Discussion 10 02-20-2011 12:46 PM
Quick wheel size question SupermanWV 2010 Dodge Ram Forum 1 02-02-2011 04:53 PM
Standard wheel size rick980 Dodge Ram Wheels And Tires 1 12-29-2010 02:31 AM
09 Ram Wheel size Q's??? Marine671 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 11-24-2009 12:18 PM
