Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-01-2011, 09:33 PM
Ivawoody's Avatar
Ivawoody Ivawoody is offline
Vehicle: 2005 Ram 1500 Big Horn
Trim Level: Royal
Color: Grey
Rep:23
Ivawoody is on a distinguished road
Default Oil Pan Gasket--Tough to Change??
How difficult is it to change the gasket on my oil pan? I have a small leak from the front of the motor, and the guy I bought the truck from told me when I bought it that it has a small leak in the oil pan gasket and even gave me the gasket to replace the old one with. I believe he said you have to undo the motor mounts, remove the distributor and prop the motor up to get the pan off. Is it really that involved??
Old 04-01-2011, 09:44 PM
sapper7 sapper7 is offline
Vehicle: 1986 D-150
Color: light blue
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:13
sapper7 is on a distinguished road
Oil pan gasket is easy to change however, I’d clean the undercarriage and re-inspect where the leak is coming from before replacing the pan gasket. Could be leak-down from another source.
Old 04-01-2011, 11:04 PM
Ivawoody's Avatar
Trim Level: Royal
Color: Grey
Rep:23
I'm only assuming its the pan gasket...the guy I bought the truck from rebuilt the engine and told me thats where it was coming from. I looked under the front of the truck today and it was definately coming from the lower front part of the motor. I will degrease it though and check just to be positive.
Old 04-06-2011, 08:50 PM
pirayaman's Avatar
pirayaman pirayaman is offline
Vehicle: 1987 le250 power ram
Trim Level: fully loaded
Color: 2 tone red white
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Rep:25
pirayaman is on a distinguished road
try to tight the bolts alittle first mine leaked to wen i got it i snugged up every bolt and it was fine and yes i think it is that invoved to change the haynes manual says you may even have to remove the exhaust in fron as well
oil change warning revisited.... muskybait 2010 Dodge Ram Forum 11 05-26-2011 10:32 PM
Qucik change oil valve-check!.. - messy oil filter change - options ? alecmcmahon 2010 Dodge Ram Forum 14 03-05-2011 07:19 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
what is the dealer time for a timing chain case inner gasket change ape stit Cummins Diesel Specific Topics 5 05-26-2010 10:28 AM
