Old 04-13-2011, 04:07 PM
Hemi flash Hemi flash is offline
Vehicle: 2011 Dodge Ram SPORT Crew
Trim Level: SPORT
Color: BLack
Hemi flash is on a distinguished road
Well I'm in Canada ---ran the VIN ---Bingo !! Wonder how long it'll be before I get a letter , or a Call? ----
Old 04-13-2011, 05:21 PM
RedDodge's Avatar
RedDodge RedDodge is offline
Vehicle: 2014 Dodge Ram
Color: Granite
Rep:25
RedDodge is on a distinguished road
Make your appointment now, seems the parts are hard to come by in some places.
Steve
www.monteman.com
Mods: Tinted front windows, UnderCover tonneau bed cover, step rails, bed mat, cabin air filter, 4 corner mud flaps, slush mats, drop in K&N filter.
Old 04-13-2011, 05:27 PM
RedDodge's Avatar
Color: Granite
Rep:25
GTYankee, I was told that the front pinoin bearing wasn't getting enough lube because the fluid wasn't getting to it due to too much flow below it. So this is something that simply gets hammered into the port to restrict flow and with the new cover the rear can be filled to a higher level. The only thing you'll need to remember for the future is that now they recommend 5oz instead of 4oz of the posi additive. Most mechanics already fill the rear until it flows out the fill hole so that shouldn't be an issue.
Steve
www.monteman.com
Old 04-13-2011, 06:24 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I'm lucky (I guess)
Got mine done this week while it was in with a BROKEN ROCKER ARM...
Old 04-13-2011, 06:34 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
here are a couple of pics of the new cover the parts guy at my dealer said he was only allowed to order 2 a week
Old 04-14-2011, 03:54 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Got my K36 recall installed Tues. the 12th of April. Took about 3 hours. The problem with the recall install kit is when the Dodge engineer wrote down what was required in the kit he failed to include the silicone gasket sealer. When the dealers get the kit they have to place a second order for the silicone. That is what the delay is.
Old 04-14-2011, 04:01 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
They made a mess with the orange sealant.
And if a mechanics shop doesn't have gasket material or silicone sealant they shouldn't be in business, that's crazy and a waste to have to order sealant for each cover install kit! Especially when the put so much on it oozes all over the place
Also I thought the new cover was supposed to have a fill hole, relocated fill, or something...
Old 04-14-2011, 04:29 PM
Rep:2657
It looks like it is just a rear cover with a hole drilled in it, that has a rubber or plastic push in plug in it
I believe the recalled units did NOT have a fill hole in the rear cover, it was in the front casting & it was too low in the casting
if it was too low in the casting, 2 things could have been happening
1) the oil slinger at the pinion gear couldn't reach the oil to keep it lubricated
2) no oil could get into the axle shafts & out to the axle bearings for lubrication
i did notice that not only was the recall from Chrysler Corp. but, it also has a NHTSA number
Ram 1500 trucks from model year 2011, which have been manufactured since September 2009, have a growl-y rear axle bearing which might seize, possibly causing the truck to stall.
Chrysler Group is recalling more than 56,000 2011 Dodge Ram 1500 pickup trucks over an issue with the rear axle bearing.
On some models built between September 2009 and December 2010, not enough lubricant was placed in the rear axle bearing. As a result, the bearing could seize, increasing the risk of an accident.
The bearing failure typically occurred within the first 500 miles, preceded by a groan or grinding noise, according to some reports.
Chrysler will notify affected owners in February. Dealerships will add 20 ounces of fluid to the rear axle bearing.
here is the actual recall
2011 Dodge Ram 1500 Recall Details
1. NHTSA Campaign ID Number: 10V656000
Recall Date:
2010-12-24
Summary:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2011 RAM 1500 TRUCKS MANUFACTURED FROM SEPTEMBER 2009 THROUGH DECEMBER 2010. SOME VEHICLES MAY HAVE EXPERIENCE A NOISE (GROWL, GRIND) COMING FROM THE REAR AXLE BEARING WHICH COULD EVENTUALLY SEIZE.
Consequences:
A FAILURE OF THE BEARING COULD CAUSE THE VEHICLE TO STALL INCREASING THE RISK OF A CRASH.
Remedy:
CHRYSLER WILL NOTIFY OWNERS AND WILL INSTALL AN OIL PORT INSERT INTO THE REAR AXLE FREE OF CHARGE. THE SAFETY RECALL BEGAN ON MARCH 4, 2011. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403
Component Affected:
SUSPENSION:REAR:AXLE:SPINDLE
Potential Cars Affected:
60,382
Notes:
CHRYSLER GROUP LLC
Old 04-14-2011, 06:00 PM
hotkarl's Avatar
hotkarl hotkarl is offline
Vehicle: 2002 Dodge Ram SLT QC 4X4
Color: Silver, PB2
hotkarl is on a distinguished road
I still have not received the "official" letter from Chrysler yet.
I found out on the website when I ran my VIN...
2011 Ram Big Horn...RIP(thanks to Hurricane Sandy)
PS2 Bright silver, Hemi Quad cab, 3:92's, most of the other bells and whistles.
1998 Dodge Durango 5.2 4X4...The family truckster!
Old 04-14-2011, 10:38 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2015 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Went to my local dealer today, they have the cover finally!!!! but they don't have the orange sealant it is on back order for 30 days. I couldn't believe it. Still waiting on my recall.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Rear Axel Fluid Recall 2011 Dodge Ram 1500 E220 Dodge Ram Recalls and TSB's. 27 03-14-2011 10:51 PM
rear diff retainer clip found today ndgo88 Suspension 0 04-04-2010 06:07 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
dodge ram rear axle 99 ram slt Dodge Ram General Discussion 1 12-18-2009 08:38 AM
Meet and Greet In The GTA Scheduled for Saturday October 25, 2008 300 Addict Dodge Ram Forum CANADA 35 10-24-2008 05:23 PM
