Old 04-02-2011, 04:39 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Default Wires through the firewall
Hey guys I'm putting air horns in and need to run power to a momentary switch then to the relay I mounted under the hood.
I was just wondering how some of you ran your wires through through the firewall. Also if any one have any suggestions on other power wires I could splice into the always have power other then the cigerette lighter.
Basically what do you guys think would be the best way to wire this switch so it could be used with/without the key in the ignition of an 05 2500.
I just looked real quick but it didnt really look like there was a simple solution. My switch is on a homemade mount off of the trailer brake controller and the relay is mounted near the fuse box but could be moved.
Old 04-02-2011, 08:55 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Look at the steering column boot there are a few dimples there that are great places to punch wires through. No suggestions on other power sources for you though.
Old 04-02-2011, 12:34 PM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
Near the Master Cylinder should be a plastic cover that is held in by 2 bolts near the brake pedal.
Mike
'04 Ram
"Yea its got a hemi!"
Old 04-02-2011, 10:16 PM
flip203 flip203 is offline
Vehicle: 2004.5 Ram 2500
Trim Level: SLT 4X4
Color: Blue
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
flip203 is on a distinguished road
I have a train horn kit on my 2500. When you look under the steering wheel there are a couple of rubber grommets that are easy to get to from the engine compartment. Is this a compressor, tank, and horns set up? If so you should have a pressure switch on the tank that tells th compressor when to turn on and off. If you don't it may be a worthy investment.
I have a 04.5 2500 so the install should be similar. Another note.... I put a switch in the middle of remote wire so that in cold times in th winter when the heater grid is running for the 1st 3 minutes I can make sure the compressor doesn't come on. If you would like to see pics of my set up let me know. Have you figured where to tie in to the horns so that when you honk the regular horns you can activate the airhorns at the same time?
Old 04-03-2011, 01:21 PM
Color: Mineral Gray
Rep:177
Well I don't have $300-$400 to spend on an actual kit unfurtunatly so I've kinda pieced a few things together. Everyone I show laughs at it but...
I got the 5 gallon tank on sale for $25, the horns and solenoid were $50 (I did alot of looking around to find the right sound) with shipping plus maybe $15 for the fittings, hose, switch, relay, etc.
I'll just have to fill the tank up at home or the gas station for now.
I spent alot of time looking around at different kits and decided I didnt want this off of the horn. I just feel better about having it on a seperate momentary switch, not really sure why.
The truck is at home and I'm back at school. The time I had time to put them in I ended up having to work on an injector problem
Hopefully Easter weekend I'll have time to wire everything
Old 04-03-2011, 05:07 PM
I push the skinny pedal
Rep:3277
Nothing wrong with piecing a kit together yourself as long as it works.
Kurtis
Old 04-03-2011, 07:05 PM
Color: Mineral Gray
Rep:177
Works great! I've had it since christmas time and have been using it by putting the solenoid leads on a drill battery. A good 20 second blast hardly dropped the 5 gallon tank 5psi (about 75 psi to 70 psi, plan on running 125 psi)
Once I get them installed I'm gonna do a seperate right up on it for anyone else who might be intrested
Old 04-03-2011, 07:24 PM
I don't see anything wrong with the pieced together setup . It'll probably work better than the expensive kits you can buy .
Spark plugs and wires? DanoHB Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 02-09-2011 11:19 PM
Help with overhead tv/dvd wires CraigsRam Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 01-12-2011 07:55 PM
Installing a brake booster. Where are the wires? BigThirsty Towing 3 12-18-2010 11:33 PM
shorty plug wires HemiGTX 5.7L V8 Specific Topics 2 11-09-2010 03:02 PM
getting wires through firewall on 2010 RandyS Custom Dodge Ram Interior and Exterior Lighting 5 08-28-2010 12:35 AM
