Old 04-02-2011, 01:53 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
Default trailer brake control not working!
so I installed the factory brake control about a month ago and finally had a chance to hook up the trailer and it doesn't work. without the trailer hooked up it shows the trailer icon with an exclamation mark, when i slide the manual brake lever it displays the gain setting (5.5) with the trailer hooked up it shows the same icon with exclamation mark but when i slide the lever it displays 99 and does not activate the brakes it seems that it doesn't acknowledge my trailer as being hooked up but when i turn on the truck lights the trailers marker lights come on. anybody have any ideas about whats this type of problem? thanks
Old 04-02-2011, 02:12 PM
JCWFLHX JCWFLHX is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Sport Quad Cab
Rep:53
JCWFLHX will become famous soon enough
Did you get the computer flashed to recognize the controller? I'm not 100% sure but I think that is the only way that it will work.
Old 04-02-2011, 04:10 PM
cudase's Avatar
cudase cudase is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
Shouldn't have to get it flashed. What types of brakes are on the trailer? It will not work with electric over hydraulic. Make sure the connections are good at the controller and trailer and that the trailer brakes actually work.
Old 04-02-2011, 09:41 PM
pjs1660's Avatar
Color: green
Rep:137
the brakes are all electric on a 2009 travel trailer all connections are fine the trailer is getting power from the truck as the marker lights work the display on the controller does not show that the trailer is hooked up i think i'll hook up yhe old control tommorrow and see if that works ok i'm wondering wether the factory control is bad or if there is a wiring issue with the truck itself
Old 04-09-2011, 03:41 PM
pjs1660's Avatar
Color: green
Rep:137
problem solved after further investigation i found that one of the 2 tabs for the positive connection on the trailer's pigtail was bent over, after unbending it it made a proper connection and everything including brakes work fine. off to the dealer on tues to get recall rear end cover and to get the brake controller flashed
Old 04-09-2011, 05:35 PM
16again's Avatar
16again 16again is offline
Trim Level: SLT Big Horn Edition
Rep:58
16again will become famous soon enough
Glad you found the issue.
Old 04-09-2011, 06:44 PM
cudase's Avatar
Rep:53
Good to hear ya got it solved.
Old 04-09-2011, 08:11 PM
pjs1660's Avatar
Color: green
Rep:137
thanks i was so ticked off last week and also didn't have time to look at it until today thankfully it was an easy fix
Old 04-09-2011, 08:25 PM
Rep:2657
Let us know just what the dealer does with the rear end repair
i wonder if they are just going to remove the cover & drill a hole in the rear cover & stick a push in plastic or rubber plug into it & fill it back up with fluid
i don't think that they will pull the cover & drill 2 holes & thread them, one for a proper drain with a magnetic plug & a threaded fill hole up at the level of the axle shafts where it belongs, so that gear oil can get out to the axle shaft bearings out by the shaft ends
Old 04-09-2011, 08:54 PM
ELFATKAT's Avatar
ELFATKAT ELFATKAT is offline
Vehicle: 2011 Dodge Ram 4x4
Rep:30
ELFATKAT is on a distinguished road
Cool Whats the flash for then?
So what does the flash do? I know you are modifying the computer settings, but what do you get out of it? Does ity simply get rid of the exclamation mark?
Where did you get the controller. I called my dealer and they said "back ordered."
I know there have been a few threads, but all the links that get posted do not go to a specific page, but to just a site and none of the part numbers that have been posted take me to a specific part.
I really would rather have the factory one instead of some little box hanging under my dash, but is it worth the price?
I will be hauling a travel trailer as well.
Thanks, and good job digging into the problem. KISS right! Keep it Simple Stupid! Not calling you stupid, but thats the saying right...
Carlos "ELFATKAT" Medina
www.carlostmedina.com
Check trailer brake warning lwalston Electrical 10 04-04-2011 10:02 PM
Trailer brake light not working dvrader Newbie Checkin! 10 02-24-2011 12:09 AM
Check trailer brake wiring warning lwalston Electrical 1 01-26-2011 06:21 PM
No power to trailer brakes, the blue brake wire has no current rraypo Electrical 1 01-09-2011 09:55 PM
Tekonsha P3 Trailer Brake Controller Doesn't Recognize Trailer GTRDude Towing 13 05-21-2010 06:56 PM
