Old 04-03-2011, 01:57 AM
OnceBit's Avatar
OnceBit OnceBit is offline
Vehicle: 2006 Reg Cab Ram SRT-10
Trim Level: SRT-10
Color: Mineral Gray
Rep:186
OnceBit has a spectacular aura aboutOnceBit has a spectacular aura about
Send a message via Yahoo to OnceBit
Default HID install on SOLAR Headlight assemblies
Thought I'd do a little write up on my HID install on aftermarket Headlight assemblies.
First off, Its a Digital 4300K H1 bulb unit from Xenon Depot.
First step, obviously remove housings...
Remove dust cover and wiring from unit and pull wires through assembly cover and remove bulb.
Found that the bulb opening wasn't quite large enough, used a dremel tool and grinding stone to open hole more, worked perfectly. Metal dust was easily blown out of housing.
Installed new HID bulb. The bulb actually had 2 sets of wiring connections but removal of the jumper harness made for a cleaner install.
making a small "X" cut in the dust boot made it very easy to run the new wires and plug ends through for a well sealed cover reinstallation.
Next came adding in the new harness jumper and resistor lead from the regular bulb harness.
As you can see it was easier just to cut off the one plug and splice the new harness directly on.
Only thing left is the Power wiring harness and Digital processor installation under the hood, very easy, just plug and play. Only need to find one power and ground for each headlight.
Now...just reinstall Headlight assemblies.
All done!
SOOO much brighter!!
MODS- K&N replacement air filter, OPTIMA red top battery, HIDs, Aftermarket light assemblies.
Old 04-03-2011, 02:54 AM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Great write-up ! I've been waiting for a more detailed write-up on a 3rd Gen. And you did it with aftermarket assemblies which is the way I want to do it, REPS !
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 04-05-2011, 01:51 AM
OnceBit's Avatar
Trim Level: SRT-10
Color: Mineral Gray
Rep:186
aww...no one else found this interesting enough to even comment on? lol
Old 04-05-2011, 02:53 AM
Chance05Ram's Avatar
Chance05Ram Chance05Ram is offline
Vehicle: 2005 Dodge ram 1500
Chance05Ram is on a distinguished road
No light output pic?
Park the truck on the street and lets see the output!
Old 04-08-2011, 12:00 AM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Nice job and great looking lights. I'm sure it will help a lot of people who want to do this. AND as long a we're requesting pics how about a nice straight stretch of road not to dark out and the rear tires lit up with the lights?? I'll give you rep for thatjk brother you get the rep anyway!
Better headlight bulbs, not HID HuntnStyle Custom Dodge Ram Interior and Exterior Lighting 17 03-07-2012 01:02 PM
HID Install (Single beam setup)...Straightforward? ArmyofOne 2009 Dodge Ram Forum 3 03-04-2011 08:26 PM
6000k HID Install!! 09Ram RT Custom Dodge Ram Interior and Exterior Lighting 15 02-12-2011 01:07 PM
Installed new headlight assemblies and now my blinkers are flashing fast and alarming steelman512 Electrical 1 10-25-2010 08:36 PM
