*Important*Tinting windows on 2009+ Chrysler vehicles - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-03-2011, 06:44 PM
Rep:3347
Exclamation *Important*Tinting windows on 2009+ Chrysler vehicles
This is very important info for people who are interested in tinting their windows on any of the new chrysler vehicles. This is from a forum that specializes in chrysler vehicle's sound/secuity systems.
ANY ONE thats planing on tinting the windows of their new 2011 chrysler needs to heed this warning!!!!!
The new glass on the chryslers [charger/300/durango/GC/and ram laramie] ARE DUAL LAYER THERMO/IMPACT GLASS.
The pros to this type of glass is to reduce road noise and reduced heat or cold in the cabin area for driver/passingers comfort.
IT's designed the same way as a front windshield = 2 layers of tempered glass with a layer of clear mylar sandwiched between.
THE other up side to this type of glass is security in a crash or if someone trys to break the glass to enter the car-the outer lay or both layers will crack like a windshield but will be held together by the mylar!!
NOW-heres the no no to tinting this type of glass.
#1 JUST LIKE IMPACT-SAFETY-HURRICANE glass for homes and commercial buildings there is a "very fine line" of what tint material that can be applied to it or the result will be over time build up of heat resulting in the glass either cracking OR delamination of the glass were the 2 layers start to pull away from them selfs at the edges and air and humidity will attack the mylar causing it to fog or turn milky white or yellow and in a short period of time will creep between the entire glass layers just like the 30's-50's GM cars glass did in the past in the corners of the glass from poor edge bonding.
SO the way around delaminated or cracked glass from over heat build up is from using a quality window film.
IT CAN NOT BE A POOR QUALITY FILM THAT ABSORB's HEAT LIKE ALL THAT $50-$100 JUNK PLASTIC TINT OUT THERE.
IT is mandatory that its a high quality mylar based window film [either metal-carbon or NANO HYBRID] that rejects the UV and heat unlike the poor quality films that trap heat and WILL over heat the glass breaking it for you from uneven heat transfer and absortion on a 90+ degree summer after noon.
BEWARNED-THE ONLY tint that can be used safely is either
#1 LLUMAR ATR OR CTX CARBON= average price of $200 for ATR or $300 for CTX carbon
#2 Huper optiks NANO carbon [owned by CPFilms-aka llumar] $350
#3 Formula One window films carbon also owned by llumar =$300
#4 3M Crystalline carbon film=$400
THE film installer as be a pro with a heat gun any were around this type of glass while heat forming the film to the shape of the glass.
THIS type of glass has been being used by mercedes on production cars since 2003
SO have lexus/porshe/audi/some fords/lamborghini/GM as standard or special option
IT's becoming commen on MOST ALL new cars-SO the tint job on your new dodge/chrysler can not be tinted by the local fly by night swap shop or corner gas station $59 tint shop.
LAST thing-this glass is expensive as in hundreds of dollars [$300] plus install for just one door glass.
NOT only is dual layer thermo/safety glass used on windshields and now side windows but is also being used on some vehicles rear windows like the MB CLS's and E350's -the caddy CTSV. Cheap tint will build up heat on the glass UNEVENLY and shatter the rear window OR CAUSE THE MYLAR layer to turn milky/foggy.
DUAL layer thermo rear windows with defrost and navi/tps antenna's inbeded in them can cost between $500-$700 or even as high as $2000 PLUS INSTALL if broken by a cheap customer and a dumb tinter with china/columbian film's
Old 04-03-2011, 07:03 PM
Wow , thanks for the heads up . What'll they think of next ?
Old 04-03-2011, 07:12 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Great info Kurtis! I had no idea that the side glass was laminated. Just assumed it was tempered glass like it has been for so many years. This is a 'most excellent' upgrade to the glass, but as the information you posted indicates, must be handled appropriately.
brad
Interested in one of my mods?
Old 04-03-2011, 07:15 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Wow, so many people have their windows tinted too. I wonder how that is going to play out.
Dillon-aka, The Little Kid
Old 04-07-2011, 03:43 PM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
Thanks for getting that out .. almost tinting time .. good to know.
Old 04-07-2011, 04:15 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
Thanks for the info!
Was thinking the exact same thing!
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 04-07-2011, 05:38 PM
metalhockey11's Avatar
metalhockey11 metalhockey11 is offline
Vehicle: 2016 Ram 1500
Trim Level: SLT quad cab 4x4
Color: Black Forest Green Pearl
metalhockey11 is on a distinguished road
any idea what yrs they started doing this to rams?
Old 04-07-2011, 06:52 PM
Rep:3347
To my knowledge, this only affects '09+ Laramies, but it's the kind of things that you should never cheap out on anyhow. Most of us will be fine since we already went with a quality tint, but the cheap stuff is what will get you into trouble.
Old 04-07-2011, 07:09 PM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Rams have had the double pane glass since I bekieve 2005, but they did not put mylar between the panes. Some of you that have tinted your windows may have already noticed. Our only problem is normally just an air bubble or two that was discovered when tinting.
Old 04-08-2011, 02:11 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I can understand the rear glass with imbedded defroster/Ant. costing a pretty dime, but the side glass being expensive? Windshields are actually cheap considering the size... But I think the whole tint thing is just somebody trying to persuede people to buy a better quality film, reason I say this is....
If the front windshield has been a laminated glass for years and never an issue, why now just because its being added as a safety issue as well as security to more vulnerable windows for injuries as well as theft? I have seen plenty of windshields tinted 1/4 to 1/2 the way down and no one has ever had issues with the glass de-laminating or cracking? On top of that, the windshield takes one heck of an abuse to debis from the road ( rocks/flying objects...ect...)
A buddy of mine owns a Tint shop, been in business several years and never had any issues with tint on windows outside of the warranty issues such as bubbles/peeling/scratches... Tint only reflects the light/UV back out to reduce heat, so it wouldnt be a tint issue for starters, it would be the glass itself if it retains the heat... My arguement would be, why would the new side windows do this if the windshield never did if its the same process?
I Am Groot !
Chrysler Canada Reports Highest July Sales since 1997 UN4GTBL Automotive Industry News and Dodge Press Releases 1 08-31-2010 12:59 PM
Chrysler Group LLC Reports July 2010 U.S. Sales Increased 5% UN4GTBL Automotive Industry News and Dodge Press Releases 1 08-04-2010 02:28 PM
Chrysler Group LLC Reports May 2010 U.S. Sales Increased 33%, Topping 100,000 Units UN4GTBL LD RAM - General Discussion 0 06-02-2010 01:05 PM
Chrysler Canada Posts 53% Sales Increase in May! UN4GTBL LD RAM - General Discussion 5 06-02-2010 03:15 AM
Owner’s manuals go digital for 2010 Chrysler vehicles 1970 Charger Automotive Industry News and Dodge Press Releases 6 09-23-2009 09:09 AM
