ZDOG
Old 04-03-2011, 08:46 PM
johnnyg23's Avatar
johnnyg23 johnnyg23 is offline
Vehicle: 1999 Dodge Ram
Trim Level: 1500 4x4
johnnyg23 is on a distinguished road
Default 99 Dodge Ram 4x4 running a little funny
Hey all, I have had this truck for about a month now. It has 123k miles on it. It normally runs awesome. No lack of power or anything. 1st of all, it has been running very rich lately. The smell is almost unbearable. 2nd, it sputters at idle, like when i'm sitting at a traffic light. It also has been backfiring at approx. 30mph, not constant though. Highway speed is great. Lastly, the check engine light came on and stayed on for 2 days. It has since gone off. In that time the light came, it hasn't run any different. Now, although it is normally bad on gas, the last week or two, it has been noticeably WAY different. It just seems like it is burning alot more fuel than normal. I looked under the hood, and it appears to have the original ignition wires, the air filter looks fairly new, but I haven't looked at the plugs yet. I can only imagine that they are not in too good a shape if the wires are original. Any ideas? Please help me out.
Old 04-03-2011, 11:06 PM
Try and get the computer scanned for you code(s) . It wouldn't hurt to do a good tune up on it also . That way you know what shape it's in . Let us know what codes are in the computer .
Old 04-06-2011, 12:46 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
If you smell rich fuel, its your O2 sensors not working properly.
Old 04-06-2011, 01:31 AM
johnnyg23's Avatar
Is that going to effect performance? I have to have the truck tested for emissions, will that prevent me from passing?
Old 04-06-2011, 02:01 AM
panhead's Avatar
Trim Level: WS
Rep:103
Depends on your area, I would look at your laws. Up here in PA, anything 96 and older, its visual and just make sure all the emission is there, no testing. Yes, your O2 sensor is going to effect the way your truck is going to run.
Old 04-06-2011, 02:14 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Scan it for codes first. Although the O2 sensors are very high on the suspect list, a code scan should verify this. Also a good tuneup never hurts.
Have you noticed excessive oil consumption too? If so, the plenum gasket could be in need of replacing.
Oh....what the heck....just jack up the rad cap and drive a new truck under it.
brad
Interested in one of my mods?
Old 04-06-2011, 09:44 AM
panhead's Avatar
Trim Level: WS
Rep:103
A faulty O2 sensor will not always throw a CEL.
Old 04-06-2011, 11:22 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
+1, totally. Hopefully, a computer scan will show bad O2. if not, see if you can watch Real Time data of the O2 and see what it reads. it should vary between .1 and .9VDC approx. if not, it's toast. if it doesn't show voltage, and instead just shows "RICH" or "LEAN" constantly with no variance, it's toast also.
Hope that helps and good luck.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-15-2011, 10:21 AM
johnnyg23's Avatar
Ok guys, well I finally had time to get the computer scanned and it came up that the # 5 cylinder is not firing. I have changed the plugs, wires, and air filter before getting it scanned in hopes that it would fix the problem. Obviously it did not. I did notice that when I removed the plugs that that # 5 plug was soaked with fuel. Could it be a bad distributer cap? or something else. Please help, it is burning an ungodly amount of fuel, way more than normal. And at $3.85 per gallon, I might have to park it and I don't want to do it.
Old 04-15-2011, 10:24 AM
panhead's Avatar
Trim Level: WS
Rep:103
Could be a bad injector.
Hey new guy with a hatred for dodge.... untill now...!! hereicome4u Newbie Checkin! 15 03-04-2011 06:53 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
New 2010 Dodge Ram owner jdolotina Newbie Checkin! 11 02-06-2010 08:53 PM
Parkers Dodge SBSignature Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 3 09-06-2009 08:06 PM
