Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 04-04-2011, 02:19 PM
bcampo1239 bcampo1239 is offline
Vehicle: 1997 Dodge Ram
bcampo1239 is on a distinguished road
Default Blown Header Gaskets
Hey everyone,
I believe I bought a 1997 Dodge RAM 1500 with blown header gaskets. Hopefully the problem isn't any worse than that. I took it to a mechanic he popped the hood and listened for a second and immediately said its blown header gaskets. (It makes a slight ticking noise and seemed to be worse during the cold weather.) I had a friend look and he said its an exhaust leak then the mechanic said its blown header gaskets.
I want to get the problem fixed however want to avoid getting ripped off again.
How much are new header gaskets and typically how much is it for a mechanic to fix?
Thanks for any help or suggestions.
Old 04-04-2011, 03:29 PM
Welcome to the forum.
Header gaskets, such as those offered by Summit Racing, run anywhere between $20 to $40 depending on material. Get a good set.
Also, get a set of Stage 8 fasteners. Most gasket blowouts are caused by header bolts backing out and loosening the seal between the header, gasket and exhaust ports. Stage 8 fasteners will not back out until you want to take them out.
This is probably a 3-4 hour job for a qualified mechanic at whatever rate the shop charges.
So many header choices Rumble04 Exhaust 1 02-13-2011 07:47 PM
Head gaskets or what? Hollywoodgt Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 3 11-02-2010 10:52 AM
Header Torque Mayhem4216 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 07-21-2010 01:34 PM
