Old 04-04-2011, 04:19 PM
AJ1500 AJ1500 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: standard
AJ1500 is on a distinguished road
Default Could use some help with OD
I'm hoping someone can answer a couple questions that might help me find a problem I'm having with my 1500
The problem is the OD won't turn off, nothing happens when you hit the button on the shifter, BUT sometimes and there is no reason for it the off light will flicker on the dash, it could happen while still in park or as soon as you put it in drive or going down the road. It does NOT effect the trans at all, the llight just flickers
Now a quick history, I repaired quite a few wiring issues that was cooking PCM's a while back, Thanks to some good advise and suggestions I got here it seems that is all behind me now, however the OD issue was and still exist since we bought the truck. This issue has never changed
OK question 1 can I remove the button at the end of the shifter without destroying it, then other than broke wires what can I check/test
2 does anyone know what wires feed the OD throught the harness so maybe a could do a continuity test on it
or know the voltage I should be looking for
Old 04-05-2011, 08:11 PM
I had issues with my '01 . The wires are very rigid and have a tendency to break at the column shifter pivot point . You can get it apart and make the necessary repairs . Mine works fine now .
Old 04-06-2011, 05:46 AM
when you say pivot point are you referring to the where the shifter moves throught the gears or the tilt steering pivot point.
so I can remove the outer colomb covers and access the wiring where it binds
Old 04-11-2011, 08:35 AM
Well I got the OD issue repaired and thought I would share what I found
First I found there is a small slot on the outer ring of the shifter at the button, you can remove this ring with a small screwdriver, then you can push the wiring from the bottom of the colomb(once cover is removed) and pull the button out
Of coarse I found this out after accidently pulling the shifter end off and pulling the wires loose from the button, it is possible that one of the wires was already loose
this would explain the flickering of the OD light in the dash
what I did first was to inspect the wiring at the pivot point, everything looked good there, so I unplugged the plug on the steering colomb and using a test wire I made a momentary switch there, after determining the OD works I then repaired the wiring at the plug for the button and hooked it all back up
It still didn't work so at this point I thought I had nothing to loose so I opened up the OD button, inside is a small circuit card and a rubber bushing with a brass button to make the contact on the card
both were glazed, so I took a pencil eraser and cleaned them and reinstalled
Now the OD turns off and back on on demand
Thanks for the help and I hope my findings will help someone with the same problem
