Old 04-04-2011, 07:23 PM
militarymopar militarymopar is offline
Vehicle: 2012 Tradesman 1500 4x4
Trim Level: Tradesman
Color: Gray
militarymopar is on a distinguished road
Default 2011 R/T Rear Diff Cover
Actually replaced the rear cover on my R/T "before" I heard about the rear diff recall. PML cover adds about 0.7 quarts over stock. It's sand cast aluminum with raised cooling fins. Notice the fill point at axle tube level with a magnetic drain at the bottom. Cleared the factory sway bar with no problems (3/4") but the panhard bar is close (3/8"). However, since the axle's fore and aft movement is controlled by the upper and lower control arms, 3/8" clearance is not a problem. I topped the rear diff with Royal Purple synthetic and MOPAR's sure-grip additive. With the aluminum cooling fins, added capacity and Royal Purple, the rear diff temp is only warm to the touch after towing 4800 lbs.
Old 04-04-2011, 08:07 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
Nice mod. It looks nice too. How does the recall affect the rest of us? Did some of them just have small pans?
Old 04-04-2011, 08:18 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
looks pretty good!
Old 04-04-2011, 08:24 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
That's an excellent mod, WTG...
Old 04-04-2011, 08:52 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Looks good, I like it a lot. There is a recall for the dif. cover check this thread. Hope that will not affect it.
http://www.ramforumz.com/showthread.php?t=78910
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 04-04-2011, 08:57 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
Looks good, Who makes the cover?
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 04-04-2011, 09:13 PM
CHVYKLR's Avatar
Rep:252
http://www.yourcovers.com/index.html
Old 04-05-2011, 12:06 AM
Rep:2657
the thing about the stock cover is it has to be removed to drain the rear end, an idiot designed it, must have been a FURD or YOTA reject
in 2009 the rear plate had a fill & fluid check hole in the rear cover, but, still no drain plug
the newer ones fill from the main body of the differential, in the casting, not a bad idea, but the same designer put the fill/check point lower than the axle shaft tubes & the oil can't get to the axle bearings, no wonder Ferd fired him, if you want to keep the axle bearings lubed, you have to drive on a side hill & turn around & go back the other way
now they are coming up with a fix, drill & thread a hole in the rear differential cover, that is above the half way mark, so the axle bearings can splash the oil around, the way it should have been in the first place
Chrysler makes a crappy automatic transmission, just like Ferd does, that is why its going to replaced with a German transmission & Ferd will follow suite
the Corporate 9.25 differential has been around forever & some stupid idiot messed up & didn't put the fill/inspection plug high enough on the new vehicles
i'm losing faith
Old 01-15-2013, 06:35 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
do you guys know if the bolt pattern for cover for the 12 bolt is the same on a 3rd gen 9.25 and the 4th gen's?
Old 01-15-2013, 06:57 PM
Rep:2657
for several years, AAM made the 9.25 axle for Dodge
in 2011 Dodge changed to using the ZF axle
I don't know if the bolt pattern is the same on both brands
This may help, this what i have on mine
http://www.mag-hytec.com/differential.htm
Rear diff service ndgo88 4.7L PowerTech V8 Specific Topics 7 04-30-2011 08:50 PM
Rear Diff Recall #10V656000 LineCutter 2011 Dodge Ram Forum 40 04-02-2011 12:17 PM
2011 rear diff oil Divemaster 2011 Dodge Ram Forum 18 03-07-2011 12:17 PM
Scatpak= New Grille, Headlights, Diff Cover and Painted Handles + Mirrors ScatPak07 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 37 02-01-2011 11:40 AM
Rear Diff fluid ?? trainplanemech Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-03-2010 09:29 AM
