Old 04-04-2011, 08:55 PM
rscarawa rscarawa is offline
Vehicle: 2006 Ram
Trim Level: STL
rscarawa is on a distinguished road
Default 2006 Ram 5.7 lifter noise
I am looking to purchase a 2006 Ram 1500 with a 5.7. It has 35000 miles on it but it has a lifter sound when it was idling. The owner said he used 5w30 oil in it and said that the noise is normal and mechanics claim it is due to pushrod clearance for fuel economy. Is this true? Should I be concerned? Is this easily correctable? Any info would help.
Thx
Scot
Old 04-04-2011, 09:03 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
if they used 5w 30 you should point out to them only 5w-20 is used with the mds engine. therefore the wrong oil is in there, says right on the filler cap. but thats not causing the lifter sound.people with the hemi my self included call that the hemi tick most hemi engines develop it sometimes in the first 20k miles, but noise and all, they are good engines nothing to worry about and there is no cure.so if it bothers you and cant live with it dont buy it.
Old 04-04-2011, 10:18 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
The hemi tick is not hurtful and well documented. I know 2 people personally who have the Hemi tick and 80k+ thousand worry free miles and there are plenty of people on the board who would say the same I agree w/ charlib if you can live w/ it get it but its nothing to worry about
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 04-04-2011, 11:31 PM
Vehicle: 2006 Ram
Trim Level: STL
Thank you for the replies.
Couple more questions.
Do these engines consume oil? Will they make it between oil changes without the need to add oil?
Since this engine is running 5w 30, you see any problems with going to 5w20? Would you use 5w 20 while towing a heavy load too?
Thx
Scot
Old 04-04-2011, 11:38 PM
Mine doesn't use oil but then again, I don't have a valve seal or piston ring problem either. Any engine will use oil if it's been abused or has a mechanical fault. The oil level of my truck is usually down 1/4 of a quart by the time I change it.
No problem going to 5w 20 oil and that is the recommended weight for all conditions on that engine.
Old 04-24-2011, 01:35 AM
lakidd135's Avatar
lakidd135 lakidd135 is offline
Vehicle: 2013 DODGE RAM 1500 LARAMIE
Trim Level: LARAMIE 4X4
Color: MAXIMUM STEEL & GRAY LOWER ACCENT
lakidd135 is on a distinguished road
Send a message via Skype™ to lakidd135
I have 2010 Laramie with 5.7 and at 4400 kilometers the engine started ticking and then went to a miss and took it in to dealer and they had to replace a broken rocker arm and rocker shaft and pushrod so when I hear the noise yes I worry
Old 04-24-2011, 02:34 AM
Rep:2657
the 2006 & newer 5.7 L engine needs 5W-20 & a quality oil filter WIX, NAPA GOLD, Mobile One, Purolator, AC DELCO, CarQuest are considered good filters
some of the other oil filters can cause an oil flow restriction & that can cause the tick also
i will be using WIX from the next oil change on
Old 04-24-2011, 11:28 AM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
My 06 ticks too ...i was told that running 87octane can effect this too??
Old 04-24-2011, 04:29 PM
^^^^ Don't think so....ticks due to octane are really knock or pre-detonation which you would hear under load, acceleration, etc...
I can't use 87...my truck refused to run on it, even when it had the stock program. 89 wasn't much better...
I have a HEMI tick at idle when its cold and that's normal. It goes away after the truck warms up a bit. I don't hear it out on the road.
Old 04-27-2011, 11:11 AM
Riverton Ram Riverton Ram is offline
Vehicle: 2006 Mega Cab 1500
Trim Level: Mega Cab
Color: Red/Silver
Riverton Ram is on a distinguished road
i too suffer from the hemi tick.
what about the hemi shake? when im sitting at a stop light, sometimes i get a shake or too. ticks and shakes. tourrettes?
Ram 2500 with engine noise. Big Ed 2010 Dodge Ram Forum 9 05-13-2015 03:22 PM
lifter noise ? billt 5.7L (345 cu in) HEMI V8 Specific Topics 2 01-12-2011 01:07 PM
'10 1500 startup lifter noise NewMexicoRam 5.7L (345 cu in) HEMI V8 Specific Topics 4 11-29-2010 03:27 PM
Lifter noise tonyj 4.7L PowerTech V8 Specific Topics 1 09-14-2009 06:35 PM
Mild lifter noise on cold start piatro12 4.7L PowerTech V8 Specific Topics 6 09-02-2009 08:46 PM
