Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-05-2011, 02:13 AM
schmitty schmitty is offline
Vehicle: 2008 dodge ram
Trim Level: big horn
schmitty is on a distinguished road
Talking front end issue
Hello all,I have a 2008 ram 4x4 with a vibration in gas pedal when turning to the right,parts that i have replaced so far are drivers side bearing hub assembly and the outer tie rod end also on the drivers side.is there something that i am missing or could the problem be on the passenger side.Thanks Schmitty
Old 04-05-2011, 10:18 PM
Muddbog's Avatar
Muddbog Muddbog is offline
Vehicle: 2007 Dodge Mega Cab 4x4
Color: 2 Tone Blue/Silver
Rep:20
Muddbog is on a distinguished road
Send a message via Yahoo to Muddbog Send a message via Skype™ to Muddbog
Well, its hard to tell without being there to look at it. I have a few questions though,
Are you running stock tires?
What aftermarket items are installed on the front axle?
Did you jack up the front-end to check for play in the front wheels?
Does it happen on hard turns or easy turns?
2007 Dodge Mega Cab 4x4 5.7 Hemi
Old 04-06-2011, 12:15 AM
Hello muddbog,i am running stock rims and tires 20",i have replaced front driver side bearing hub assembly and outer tie rod end on same side,there was a little play that is when i replaced tie rod end and you can feel a slight vibration on the gas pedal when turning to the right taking it easy or when turning very sharp. thanks alot
Old 04-07-2011, 08:16 AM
Muddbog's Avatar
Rep:20
The Dodge Trucks have a slight vibration when making turns which comes from the differential. You could try something similar to this http://www.amsoil.com/storefront/ada.aspx
Old 03-06-2012, 10:14 AM
srob34 srob34 is offline
Vehicle: 07 Dodge Ram 1500 4x4
Color: silver
srob34 is on a distinguished road
Hey schmitty, I have a 2007 1500 4x4. I was having the same problem. Where did u get ur tie rod ends? I thought it was my bearings come to find out it was the tie.rod ends. Both sides were bacd. Did u have any problems screwing the tie rod ends to the tie rod?
Old 03-06-2012, 10:48 AM
goatfan28 goatfan28 is offline
Vehicle: 2005 dodge ram larmie 4x4 quad
Color: alantic blue pearl
goatfan28 is on a distinguished road
I have learned through time that anytime u have to replace tie rods or hug bearings and even brakes u should replace them in pairs cause if oneis bad chances are the other isn t to far behind.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-12-2011 11:30 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 10:48 PM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 08:26 PM
