Old 04-05-2011, 03:25 AM
kennerplaya kennerplaya is offline
Vehicle: 2003 dodge ram 1500
Trim Level: 1500
Color: grey
kennerplaya is on a distinguished road
Default someone plz help
ok my thruck first blew a radiator and fluid got all over the engine block...i fixed the radiator and since it has not been able to get over 3K RPM... it boggs out and wont go anymore....i checked the plugs and they were dripping with water/antifreeze ect. i took them out and cleaned them up but still the same problem... dont know what else it could be someone plz help me out. it is a 2003 ram 4 door 4.7
Old 04-05-2011, 08:17 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
That sounds almost 100% like a failed headgasket. Do a search on here and google for failed headgaskets, lots of information to be found. The bad news is be prepared to pay anywhere from $1K to $2K depending on which mechanic you bring it to.
Sure it'll suck, but it'll make you a man
Old 04-05-2011, 08:30 AM
Trim Level: 1500
Color: grey
well since i put the new radiator on it hasnt even got close to overheating or anything, it stays right below halfway....i cleaned up the plugs some more and it seems to be doing better now....it still sputtering but i can get it to rev up to 5K now....you think maybe it could just be the moisture working its way out? also i put injector cleaner through it....hopefully it continues to improve. tommaro im gonna test the TPS and have my buddy use his code reader on it and see what comes up...
Old 04-05-2011, 09:03 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
When you pulled the plugs, was there water in the cylinder? Check your oil, does it look milky white? If so that is water mixing with your oil= headgasket fail. Is water coming out of your exhaust, or does your exhaust smell like antifreeze? Do you have a check engine light? Likely if you have a bad sensor you will have a check engine light. Also pay attention to you water level going down or oil level going up without adding anything.
I didnt want to jump to conclusions, but the 4.7 liter is notorious for blowing headgaskets. The radiator blowing up in an indicator of pressure buildup from exhaust gas. Great that you fixed it, but the truck still doesnt run like its supposed to, even after you dried everything.
Old 04-05-2011, 09:34 AM
Trim Level: 1500
Color: grey
so far so good...oil is normal...dark but normal (need oil change). since i dried out the plugs they have stayed dry so far, only the four plugs on the driver side were wet (where the fluid was spraing out the radiator)...i pull them out everytime i go somewhere now...lol. im gonna drive it around some more today and see what happens...there was always a check engine light on... mass airflow sensor, i beleive it is from my intake never could get it to go away...thanks for the input i appriciate it... ill let you know later today where it stands...
wish i would have found this forum before i got this truck...would never have bought a 4.7 dodge
Old 04-05-2011, 03:10 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I had a 4.7 on my '06 and ran a flawless 98,000 miles on it by doing oil changes every 5k and following dodges reccomended services. It was a good engine but I want mo-power.
I'd keep an eye on the head gasket as recommended.
Drop by the Newbie Checkin for a big HELLO and a warm Carolina Welcome! I'm sure you'll be enjoying all the ForumZ has to offer!
Old 04-05-2011, 04:26 PM
Trim Level: 1500
Color: grey
yep still not running right??!! it wont make its mind up if it wants to work or not....guess ill start looking into the blown head gasket deal...!@#$%.. .lol. thanks for the help.
