Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-05-2011, 10:51 AM
RamHer2 RamHer2 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
RamHer2 is on a distinguished road
Angry 2000 Ram 1500 4x4 5.2 Trans Re-built but still have problems
Hi All,
Here is my problem....I had my transmission rebuilt and after two weeks i got it back. It is in the shop again!!! They rebuilt the whole transmission however now it takes off in second, they have changed the solenoids and are now in the process of changing the valve body. The thing is, is that when they would clear the codes for the solenoids the truck would work fine for a couple of hours and then back to taking off in second. This work is under warranty, but what a pain in the ass. I've driven the truck for a total of two hours in the last three weeks. Any help would be appreciated.
Old 04-14-2011, 10:42 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Could be a bad solenoid and governor. If they replace the valve body they will end up replacing the solenoid and governor. If they do it properly and it still just takes off look into another repair place and possibly have the ECM checked at a reputable Dodge Dealership. If it does end up needing a new ECM, DO NOT GET IT FROM THE DEALER unless under warranty. A replacement ECM from a dealer not under warranty would cost hundreds of bucks, go on ebay instead you can pick one up for 50-150 bucks be sure the module number on the ECM you buy matches the ECM you have.
Old 05-03-2011, 03:51 PM
bluewhale bluewhale is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: base
Color: blue
bluewhale is on a distinguished road
Sounds like the transmission is being forced into a failsafe mode if it will operate normally for a while after codes are cleared as you state and then loose 1st gear after a short time. The code that is being stored may be the clue to what problem is. What code is being stored??
Erratic Idle and dying problems on 97' 1500 5.9L chrismcr6 5.9L V8 Specific Topics 8 01-26-2012 10:32 PM
Trans problems???? johnnyg23 5.9L V8 Specific Topics 2 03-06-2011 01:02 PM
Dodge 1500 5.2 problems. Help, please? dclange 5.2L V8 Specific Topics 8 04-18-2010 12:57 AM
Looking at Buying 2000 Ram 1500 aspivek Dodge Ram General Discussion 6 04-08-2009 12:38 AM
1998 trans. stick 5 sp. in 1997 1500 2 WD. WM300 V6 Specific Topics 0 02-26-2009 01:20 AM
= Copyright a Network Site =Ad Management by RedTyger
