Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 04-05-2011, 12:07 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Default Suspension helpers
Okay, so I am tired of the squat in my truck when I have it loaded with 800 or so pounds in the bed, let alone when I add a trailer. So, I am looking at helper options.
I have been recommended the Timbren spacers, but I wonder if that will create added stress on the axle tubes, since they will be adding pressure any time the truck compresses the light duty portion of the springs.
The second option I have considered is an air bag system. I like this option, because I could add a compressor and tank on the truck which would come in handy for numerous things. However, I am not sure how they work with the coil springs. I have seen them on leaf springs, and they sit between the spring pack and the frame. The ones I have seen for coils go inside the coil, and I would be afraid of them binding up in there.
Anyone have any thoughts on which way I should go?
Thanks in advance.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 04-05-2011, 12:18 PM
dirtrider29's Avatar
dirtrider29 dirtrider29 is offline
Vehicle: 2007 Dodge ram
Color: mineral grey
Rep:15
dirtrider29 is on a distinguished road
I would go with the air bag set up I don't have them but a lot of other people on the site do and they seem very happy with the set up
Old 04-06-2011, 10:28 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The air bags work great with the coil springs, so don't worry about that. I just find they are a bit expensive, and have a compressor that will require maintenance at some point.
I went with the Timbren SES system, and am very pleased. My truck normally is pulling about 6200lbs of trailer, and sits on the SES. I have not noticed any issues, but rather have noticed how nice the ride is when on the SES. It is not as rigid as it might appear. Gives more the feeling of 3/4 ton suspension.....firm, but flexible.
Benefits -
Airbag - adjustable
SES - Inexpensive and easy to install
Both are great choices IMO.
brad
Interested in one of my mods?
Old 04-07-2011, 05:40 PM
Wildcat's Avatar
Rep:166
These are the Air Bags I was thinking about, and they are way less than the $200 or so for the Timbrens. I have the compressor at home, but if I wanted to go with OBA, which I do, the price will easily be more after $400 or so for the OBA.
Old 04-07-2011, 07:52 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
Why not air shocks? I know they are hard to find. Kind of the same setup as air ride...
Look into it, it might be a better route for you.
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 04-13-2011, 12:05 AM
libertyfiremedic libertyfiremedic is offline
Rep:54
libertyfiremedic will become famous soon enough
Airlift makes a system we just put in a dodge. He towed with it this weekend and said it worked great. It's also pretty inexpensive.... MSRP on the website is around $127. Then you can add your compressor.
Old 04-13-2011, 11:08 AM
Wildcat's Avatar
Rep:166
Thanks for the positive feedback. That is the one I was looking at. I found it for like $90 on the web.
I notice that you appear to be an EMT in Liberty. Not sure how to go about it, but there is a group on here of first responders you should look into joining.
Old 04-13-2011, 01:08 PM
blue09's Avatar
blue09 blue09 is offline
Vehicle: 2012 Ram 1500cc
Rep:19
blue09 is on a distinguished road
I have the airlift system. It works great, put it in myself and it was easy. I would reccommend this kit to anyone.
Old 04-15-2011, 07:31 PM
jonnyriabov jonnyriabov is offline
jonnyriabov is on a distinguished road
Default leveling kit and Airlift System
Does anyone know if the Airlift system will still work on trucks that have the rear spring spacer that comes with leveling kits. Im wondering if the upper spacer and retaining bolt are where the airline is supposed to go.
Jonny
Old 04-20-2011, 02:51 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
the bags are more rigid/stiffer than you think and I wouldn't worry about them binding up especially if you keep them at the recommended min psi (3-5 I think).
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 164 12-04-2015 11:58 AM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Body lift vs Suspension lift ccga3359 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 12-19-2010 09:22 PM
1986 ram suspension components and parts.....HELP!!!!! ONENIGHTSIGHED Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 09-25-2010 08:35 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 06:57 AM
