Suspension helpers - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-28-2011, 01:09 AM
fowler2000's Avatar
fowler2000 fowler2000 is offline
Vehicle: 2012 dodge ram
Trim Level: slt loan star
fowler2000 is on a distinguished road
I have the Timbrens on my truck and I swear that you would snap your axle in two before you squat your truck ever again (I have had 3000lbs in bed and pulling a trailer at the same time). That said I have had no complaints or problems in the 5+ years that they have been on my truck.
Old 05-26-2011, 08:55 PM
rinnels69's Avatar
rinnels69 rinnels69 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:19
rinnels69 is on a distinguished road
I had air bags on my 05 Titan and even with them at the minimum of 3 psi, the ride was terrible compared to stock. I installed the Timbren SES about 2 weeks ago on my Ram and haven't noticed a difference in the stock ride...still smooth as silk. And NO maintainance or air lines to worry about!!! I'll let ya know how it does towing a 30' travel trailer next week.
MODS: G2, Timbren SES, ITBC, de-badged....to-do--HB horns and nerf bars
Old 06-03-2011, 08:33 PM
rinnels69's Avatar
Rep:19
Well, I towed a 30' travel trailer about 70 miles, in somewhat hilly country...between Grapeland and Mexia TX. The dry weight was about 5500 lbs, two axles. The quick connect factory ITBC worked great--I call it quick connect because from start to finish was 8 minutes !!! The truck did great, with the exception of a few of the "larger" hills.
The big question: Would I regularly tow something this size/weight? No, but for the occaisional job, it did just fine. The tranny temp never went over 180 degrees F and the outside temp was about 90-95 degrees.
As far as the suspension, when we lowered the trailer onto the hitch (weight distributing), the truck squated to a level stance...the Timbren SES worked just as advertised.
Overall, I'm very happy with the truck and it's towing capability, and along with the Timbren SES, I truely feel it will handle anything I throw its way, as long as I use some common sense, which is JUST AS important as a GVWR recommendation.
Old 06-04-2011, 11:11 PM
bucholj's Avatar
bucholj bucholj is offline
Trim Level: Bighorn
Rep:26
bucholj is on a distinguished road
Rinnels69, if I may ask what gears do you have 3.55 or 3.92?
Old 06-04-2011, 11:35 PM
rinnels69's Avatar
Rep:19
3.55's...............(had to add this to get it to post).
Old 06-05-2011, 10:48 AM
bucholj's Avatar
Trim Level: Bighorn
Rep:26
Rinnels69, I appreciate all the info. Thanks!
Old 06-16-2011, 09:03 PM
emmyshemi's Avatar
emmyshemi emmyshemi is offline
Vehicle: 2017 Ram 1500 crew 4x4,
Color: Max Steel
emmyshemi is on a distinguished road
I had added the airlift 1000 helpers to the rear springs. what a huge diffrence when pulling my travel trailer. no more sag, 100% level, and much more stable. I got them from autoanything .com...less than $80 bucks. I ran the lines to a T fitting, then 1 valve stem out of the back of the truck (Just to the right of the license plate). I just drilled a hole in the plastic, and ran it out of the back. They were easy to install, and work great. There is no need for a compressor. They are a great product, you wont be disappointed. A must for heavy towing.
How about I put my "carbon footprint" up your liberal ass?
Old 06-17-2011, 11:20 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Did the air bags affect the ride quality empty at all?
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-17-2011, 12:23 PM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
If you have the minimum 5psi in them you won't know they are even there. I keep mine around 15psi and I like the ride even better than stock (but I almost always have something in the bed and passengers in the cab).
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 06-17-2011, 12:52 PM
Wildcat's Avatar
Rep:166
Good to hear. I have a couple hundred pounds in the tool box in the bed, and then at least 2 passengers, so I shouldn't have any issues.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Body lift vs Suspension lift ccga3359 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 12-19-2010 09:22 PM
1986 ram suspension components and parts.....HELP!!!!! ONENIGHTSIGHED Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 09-25-2010 07:35 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 05:57 AM
