Old 04-05-2011, 07:17 PM
MMMMDude MMMMDude is offline
MMMMDude is on a distinguished road
Default Battery Drains when Truck is parked
Hey Guys,
Need help.
I have a 98 Dodge Ram 1500 V8 5.9L.
Recently I replace alternator and battery. Afterwards truck sat for about a week. When I went to start - totally dead. Thought I had a bad battery so I replaced battery. Put in new battery and after about 4 days truck dead again.
Can an alternator draw voltage from battery if engine is off?
Something is drawing power from battery when everything is off and engine not running.
Pulled fuses while voltmeter on battery terminals - No significant differents.
Only thing I can think of is to pull a fuse and leave off for a couple of days then test battery drain.
Anybody have a better way?
Any ideas what I can do to ID?
Looking forward to any reply.
Thx
Mike
Old 04-05-2011, 08:49 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Do you have an accesories that might be drawing power? I dont think your alternator the problem.
I would go through and pull each fuse and check with a test light or multimeter to see if anything is pulling power with the key out of the ignition.
Old 04-06-2011, 02:40 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
If you know someone with an 'Amp Meter' that knows how to use it, they could hook it into the battery line to measure the actual current draw. Then remove the fuses until the current drops. Under normal circumstances, I believe the current draw should be less than 30ma.
brad
Interested in one of my mods?
Old 04-06-2011, 02:53 AM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
or get a battery disconnect put in....that'll cure all of it lol
DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
-Jeff
Old 04-06-2011, 04:17 AM
Color: Mineral Gray
Rep:177
I wouldnt recommend a battery disconnect.
Only being a temporary solution it'll cost you batteries in the long run. While your battery seems to be slowly drawing power, charging and discharging the battery that much will kill you battery life.
Old 04-06-2011, 04:23 AM
jc4041's Avatar
Rep:146
I had one on my muddin samurai for years without any issues...guess I was just lucky
-Jeff
Old 04-06-2011, 07:37 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Mine was doing the same thing and I narrowed it down to the Garmin GPS. Even though the GPS was shut off I had it plugged into the assy plug and that along with the vehicle alarm system the battery would drain down in a few days because it never had a chance to get to a full charge. I now unplug the Garmin when I am parked at home for the night and all is well. Just look at the things you may have added. One other time it was draining was when I would leave the Edge Programmer Pod plugged in and the pod would still monitor the engine even while the truck was off. Good luck to you.
Old 04-06-2011, 07:58 AM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Originally Posted by MMMMDude View Post
Hey Guys,
Need help.
Thx
Mike
OK ,,key off,,hood open,,,doors shut, unplug the under hood lamp. Disconnect pos battery cable and put an amp meter, on the highest scale, in series with the cable to the battery,,digital meter preferred. If you have an off key draw of any amount,,, first disco the hot wire from the back of the alternator and see if it goes away. If not pull each fuse ,1 at a time, until it goes away.
Old 04-06-2011, 10:29 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
do you have tinted windows? and, by chance, is your dome light left on? i know it sounds too simple and obvious, but we've had customers bring in their vehicles for the same problem....and that's all it was. just throwing ideas out there.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-06-2011, 11:11 AM
jgshannon jgshannon is offline
Vehicle: 2005 Dodge Ram 1500
jgshannon is on a distinguished road
It could very well be your alternator. If one of those diodes goes bad it can cause a significant draw. I would just take it down to your local auto parts store and have them check your charging system out for you. That should narrow it down. I know I had that happen in my Probe and it wound up being a bad relay and the entire fusebox so it really could be anything. I had to take it to a mechanic to figure that out.
Truck WONT Start. bransonshemi Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 16 01-18-2011 05:57 PM
2008 Dodge Ram 1500 - battery chapala01 Electrical 7 10-06-2010 02:06 AM
Bought truck yesterday and having shifting problems today! scubasteve6902 5.7L V8 Specific Topics 10 08-09-2010 12:41 PM
Truck Bed Crooked?? Kdrake 2009 Dodge Ram Forum 9 03-02-2010 01:25 PM
First truck, 96 dodge 1500 5.9 (auto) questions and concerns GsxR1000Ryda 5.9L V8 Specific Topics 18 10-19-2009 01:40 PM
