Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 04-06-2011, 11:17 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
don't be surprised if it's a burnt wire too. we had a car that was draining the battery something fierce. after much ripping, we found the wiring harness behind the rear seat, under the body panels, had got hot at some point and made it a big gob of a mess of wires. had to peel it apart to find the offending wire was just barely touching the chassis. WTH??
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-16-2011, 11:12 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
Default Battery drain
I had an S10 blazer before and had the battery drain problem also, come to find out the pos battery cable going to the starter had rubbed an open spot in the insulation and was rubbing on the frame. I changed the cable and inserted the cable into some clear tubing for added protection and solved my draining problem hope this helps you..
Old 04-17-2011, 08:18 PM
tosh
I've got a 02 ram 1500, same problem so pit amp mtr in series to pos bat term, meter would read .02, then jump tp 1.05 amp draw foe around 30 seconds then drop back to .02 sit there for about a minute and junp back up to 1.05 and it kept cycling at this. i started pulling fuses and tracked it down to fuse #51, cluster lights, hood lamp, and radio. i know the radio keeps the time ans channel selectiom but this sounds like a mal function. i'd like to take the radio off the circuit to check it but dont know a good way to do this,,any ideas???
Old 04-17-2011, 10:28 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
About the only way is to unplug the connector(s) from the back of the radio unit.
brad
Interested in one of my mods?
Old 04-26-2011, 01:48 AM
STLRam's Avatar
STLRam STLRam is offline
Vehicle: 2009 RAM 1500
Color: Gray
STLRam is on a distinguished road
i just started having that problem on my 09. Found a major amp drain from athe power cable back to my system that i took out a year ago, but never removed the wire itself. Just left it hooked to the battery and capped off in the back if i ever decided to put it back in. After testing it at auto zone for 5 mins that cable drained 15 amps. Found an exposed part going through the firewall grounding out to the frame.
Old 04-26-2011, 11:35 PM
brad12kx's Avatar
Rep:2581
Good thing it didn't start a fire......or did have a big fuse at the battery connection.
brad
Old 04-27-2011, 12:11 AM
STLRam's Avatar
Color: Gray
Default IOD Shorting out
yea man i left the fuse in it. as an electrician i know my way around voltage and wiring,(no offense) although off to work this mornig battery dead again!...spent 3 hours checking fuses and bare wiring. came to the last fuse in my fuse box. 60 amp incased in a plastic locking device. my "IOD" fuse that controls radio, keyless entry, and my display screen. Owners manual states that fuse "is to be removed if stored for more than 2 weeks to prevent battery drain"... in my case that fuse is completeing the circuit to my battery drainage.THAT SUCKS!... Does anyone know where i can go from here?
Old 04-27-2011, 12:30 AM
brad12kx's Avatar
Rep:2581
The IOD Fuse - J15 - 60A distributes it's output as follows -
M38 (20A) - Multifunction Switch and Instrument Cluster
M39 (30A) - Radio and Amplifiers
M41 (15A) - Hands Free, Compass, Video Screen and Satellite Radio Modules
M42 (10A) - A/C Heater control and Underhood lamp.
I'd look at M42 first.....the 'ol underhood lamp staying on trick has caused many a dead battery over the years.
Let me know if you want the complete power distribution drawings.
BTW - Average power drain should only be about 30ma with the truck shut off, doors closed....etc. etc.
brad
Old 05-07-2011, 02:08 AM
STLRam's Avatar
Color: Gray
Thanks for the info, i took my truck to the dealer last week. They said they found the short in my switch cluster that controled Tow/Haul, traction control, hazards, power converter, etc. After 200 bucks for labor and 54 for the switch, It stopped my drain...for about a week. I still say its part of the I.O.D. Specificly the keyless entry, as long as i dont hit lock and unlock, my ram will start just fine. i guess back to the drawing boards. later
Old 05-09-2011, 09:43 PM
mikedirtbike mikedirtbike is offline
Vehicle: 1998 ram 1500 4x4 5.2
mikedirtbike is on a distinguished road
I'm having the same problem. When i unhook the pos side of battery and put my multi meter in series i get a reading of 13.03 volts..
2008 Dodge Ram 1500 - battery chapala01 Electrical 11 12-10-2015 12:19 AM
Truck Bed Crooked?? Kdrake 2009 Dodge Ram Forum 15 09-07-2015 10:50 PM
Truck WONT Start. bransonshemi Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 16 01-18-2011 05:57 PM
Bought truck yesterday and having shifting problems today! scubasteve6902 5.7L V8 Specific Topics 10 08-09-2010 11:41 AM
First truck, 96 dodge 1500 5.9 (auto) questions and concerns GsxR1000Ryda 5.9L V8 Specific Topics 18 10-19-2009 12:40 PM
