Old 05-09-2011, 11:05 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by mikedirtbike View Post
I'm having the same problem. When i unhook the pos side of battery and put my multi meter in series i get a reading of 13.03 volts..
The reading is expected...and good. However, it's the wrong test.
To test for IOD, you need to measure 'amp'....or in this case, milliamps. (thousandths of an amp).
WARNING - This test can cause serious and irreparable damage to your meter if performed wrong!
Perform the following test at your own risk!
Because we are testing for a possible over-current condition, we need to test in the 'amps' range first.
To test the IOD current draw -
1) Disconnect the underhood light if applicable.
2) Ensure all lights are off, doors are closed, keys are NOT in the ignition, and no-one is around to accidentally open a door during the test.
3) Disconnect the negative battery cable. (Although the test can be done on the positive side, it is recommended to do so on the negative side.)
4) Select the DC 'Amps' range on the meter. (Usually shows the letter 'A' with both a solid and dashed straight line under the 'A')
5) Move the positive lead of the meter to the jack marked with the same symbol (A with underline).
6) Connect the Red meter lead to the negative battery cable.
7) Connect the Black meter lead to the negative battery terminal.
Never, NeVeR, NEVER, connect the leads across the battery terminals in this mode.
If the reading starts with 3 'zero's', then disconnect the meter, adjust the dial to milliamps (mA), move the red lead to the jack with the same marking (some meters share the same jack for both settings....but most don't), then repeat step 6 & 7.
The number you looking for on the meter in this test is 35 or smaller. OEM spec is about 30.
After completing the test, move the red meter lead back to the 'V' jack, so the meter is in a save setting.......then let us know what the test showed.
brad
Interested in one of my mods?
Old 05-10-2011, 05:18 PM
mikedirtbike mikedirtbike is offline
Vehicle: 1998 ram 1500 4x4 5.2
mikedirtbike is on a distinguished road
I guess i'm using the wrong meter, So i need to shoot for 30ma+- .we'll do thanks.
Old 10-24-2011, 04:33 PM
stude2 stude2 is offline
Vehicle: 1998 Dodge Ram
stude2 is on a distinguished road
Just posted a question for same problem, used amp gauge ,4 amp drain pulled all fusses and breakers only main 50 amp dropped drain, checking further could hear seat belt retractors activating with key off, unplugged under seats problem gone but cant use seat belts need help finding why solenoids are activating
Old 01-24-2013, 03:28 PM
b3nko b3nko is offline
Vehicle: 2008 Ram Laramie 5.7L Hemi
b3nko is on a distinguished road
Thumbs up
Hey! So I used this thread to diagnose the problem and did in fact trace it to the "Ignition Off Draw (IOD)-Cabin Compartment Node" so thanks for the technical advice in that aspect. But, what should I do now? How can I further trace it to the culprit? Thanks in advance for your help, it is greatly appreciated...
Old 01-24-2013, 11:21 PM
brad12kx's Avatar
Rep:2581
Being a 2008, I take it you traced this to fuse 11. That being the case, here are the items that are powered (or partially powered) by this IOD fuse -
  • Underhood lamp
  • Radio
  • Remote Entry/Sentry Key module
  • Instrument cluster
  • Hands Free module
  • Satellite receiver
  • Media system (Monitors/DVD)
  • Electronic overhead module
The first thing to check is that you have disconnected the underhood light. This little critter has bit many a tech in the butt; it's an easy one to forget about.
After verifying that, the only thing you can do is disconnect one item at a time to see where how it affects the IOD current. Also of note, fuse 11 also supplies power to the Data Link connector (Diagnostics Jack) under the dash. Any chance you have some sort of electronic metering device connected to this port or someone has tapped into this 'power wire' to power some device??
Good luck in your tracing and keep us posted.
brad
Old 01-31-2013, 10:20 AM
  • Underhood lamp
  • Radio
  • Hands Free module
Ok so here's the update: It was getting worse and worse to the point where instead of being dead after 2 days, then 1 day, then several hours, then it died in under an hour and I mean DIED, as in no power at allll.... so I went back to basics: had the brand-new battery I purchased tested and it only had 450cca after driving 30min (with a good alternator) to this place, so we took it out, had it charged and re-tested: it was a dud! So I replaced it and had the new one tested before installation and it had 700cca off the shelf. So far so good, NO ELECTRICAL problems or drains, it just fires right up, with the remote start and everything. Anyway, I think I got REALLY REALLY lucky and hopefully it's good as new... if not, I'll post back lol. Thanks again for your support y'all!
Old 07-08-2014, 07:51 PM
rdbradleyjr rdbradleyjr is offline
Vehicle: 2001 Dodge Ram SLT
rdbradleyjr is on a distinguished road
So I have the same problem but in reading this I think mine may be more than a fuse. On Friday my truck would not start. I took my alternator and battery up to Autozone to have them checked. The alternator tested ok but the battery was too dead to tell if it was faulty. So I replaced the battery and re-installed everything. The truck started up just fine, no problems whatsoever. Sunday afternoon I went to drive it and it was dead. And I mean dead, dead. Not a light, nothing. I didn't even drive the thing from the time I replaced the battery to Sunday when I tried to start it. I don't have anything after market on the truck. It's the original tape deck. What the heck can drain a brand new battery between Friday afternoon and Sunday afternoon?
Old 07-08-2014, 08:18 PM
Sounds like mine... Sorry I didn't post back like I said I would, but within a week of that last post, it started doing the same thing. So, i took the battery back to Autozone and traded it for another battery that had the highest Cranking-Amps rating. Apparently, The HEMI takes a lot of juice to turn over and once I changed that battery to one with more cranking amps it was fixed PERMANENTLY. Amps are the thing that don't reallt get replenished by the Alternator with regular driving... Good luck!
Old 12-17-2014, 11:58 PM
RarestofMetals RarestofMetals is offline
Vehicle: 1999 Dodge Ram 1500 4x4
Trim Level: Standard
Color: Blue
RarestofMetals is on a distinguished road
Talking My Dead Battery and How I Fixed it
Originally Posted by MMMMDude View Post
Hey Guys,
Need help.
I have a 98 Dodge Ram 1500 V8 5.9L.
Recently I replace alternator and battery. Afterwards truck sat for about a week. When I went to start - totally dead. Thought I had a bad battery so I replaced battery. Put in new battery and after about 4 days truck dead again.
Can an alternator draw voltage from battery if engine is off?
Something is drawing power from battery when everything is off and engine not running.
Pulled fuses while voltmeter on battery terminals - No significant differents.
Only thing I can think of is to pull a fuse and leave off for a couple of days then test battery drain.
Anybody have a better way?
Any ideas what I can do to ID?
Looking forward to any reply.
Thx
Mike
Hi, I'm a new poster/member and I had to chime in on this thread because I had the same problem with my 1999 Dodge 4x4 truck - dead battery after no use.
Well, I found the problem - (((( it was me ))) - I hope this helps because it was so embarrassingly easy, I nearly laughed at myself to death.
Like many posters, I went through all of the culprits, bad battery - replaced with an Odyssey, bad alternator - replaced with new, loose wiring - nope, burned wiring, nothing. Nothing showed up.
So, I started pulling fuses. First, was the IOD, that worked for a few days but after a couple of days of not running the engine, the battery would not turn over the truck - just like before.
I started pulling other fuses, still had the same trouble.
All the while, my wipers would turn on, my radio would turn on, and other electrics would all turn on, so I thought it must be a grounding issue. So, I began chasing wires, still ended with nothing, nothing was wrong with the electrical system.
I was just about to take it to a mechanic when I happened to look at the ignition switch of the truck. That's when I saw it....
((((( I was turning the key all the way to the last position on the ignition )))
This is the accessory part of the ignition, the whole problem was me. I was turning the key all the way to the very back part of the ignition of the truck and leaving the accessories on, that's why the radio turned on, why the windshield wipers turned on, etc. .
Since figuring it out, I have had no other problems with a dead battery.
I hope this helps someone else save time and cash.
Truck WONT Start. bransonshemi Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 16 01-18-2011 04:57 PM
2008 Dodge Ram 1500 - battery chapala01 Electrical 7 10-06-2010 01:06 AM
Bought truck yesterday and having shifting problems today! scubasteve6902 5.7L V8 Specific Topics 10 08-09-2010 11:41 AM
Truck Bed Crooked?? Kdrake 2009 Dodge Ram Forum 9 03-02-2010 12:25 PM
First truck, 96 dodge 1500 5.9 (auto) questions and concerns GsxR1000Ryda 5.9L V8 Specific Topics 18 10-19-2009 12:40 PM
