Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2009 Dodge Ram Forum
Old 04-05-2011, 06:20 PM
babyface1223's Avatar
babyface1223 babyface1223 is offline
Vehicle: 2009 dodge ram 1500slt
Trim Level: big horn
babyface1223 is on a distinguished road
Default Small green light in console
Ok here is my problem, I want to change this dumb little green light in the center next to the map lights as well as the one on the bottom that lights up the little tray in the center console when you turn lights on. The lights run constant with the havc lights that light up the instruments which is also green gerrrr. My question is does anyone know if its a componet L.E.D. light? or what size is the bulbs are? and finally is it a 12volt socket they go into. I also want to change the hvac lights for the instuments as well if anyone knows any specs on what to buy and where etc... etc... . I hate not knowing what exactly the wording these lights are called and really fustrated not knowing size, what bulb, and voltage. In need of detail before i go nutz.
Old 04-05-2011, 09:40 PM
sudsy's Avatar
sudsy sudsy is offline
Vehicle: 2009 Dodge Ram
Rep:97
sudsy will become famous soon enough
Try downloading the service manual a check the wiring diagrams!! Good luck
Old 04-05-2011, 10:33 PM
akins9753's Avatar
akins9753 akins9753 is offline
Vehicle: 2009 Dodge Ram C/C
Color: Sunburst Orange Pearl
Rep:51
akins9753 will become famous soon enough
I changed out the light in the map upper console. I simply centered a 5mm LED light in orange to match my interior color scheme. It looks like a McDonalds Fry Warmer light but add's ambiance to the intrerior.
2009 Ram SLT, Sunburst Orange
2009 Saturn Sky, Chili Pepper
Old 04-07-2011, 06:53 PM
was the orange light you installed green prior? you said it was 5mm do you remember if it went into a 12volt socket?
Old 04-08-2011, 10:33 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Well the light on the console right at the bottom of the bezel used to green on mine I knocked out the green plastic that is over the bulb so that might be a clue if it is led or not but you can take the wire out of that area and hide it up in the dash somewhere if you cannot remove it, but it does come off the bezel. pretty easy removal just do a search.
Old 04-08-2011, 10:48 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
this site may answer some questions
http://www.dodge.com/bodybuilder/year.pdf
Old 04-09-2011, 06:28 AM
thx i will look into that site but i so far have had no luck at after market dealers as they tell me they have not done that before and doont know what kind of componet i have or volt.
Old 04-13-2011, 05:18 PM
1badram's Avatar
1badram 1badram is offline
Trim Level: Bighorn
Rep:22
1badram is on a distinguished road
i changed those lights all for red replacements. the center green light can be replaced with a 5mm led and i used red bulbs from canadian tire to replace the two overhead lights, and a red led cluster to replace the backseat int light....
2009 Dodge Ram 1500 SLT Bighorn 4x4 5.7l hemi
Old 04-13-2011, 06:33 PM
Cool
banging my head on this trend.... man everywhere i go to have someone tell me they have no idea what im talking about, or will not ,does not do that kind of work, but they were willing to replace the whole dash if i wanted to " i bet they would". Anyway thanks for the insite you are the first person to actually say what size the bulbs are in the truck. Can i ask if all the bulbs are 5mm behind the dash???? or was it just for the bulbs that were next to the map lights? my main goal is to find the size and shape so i can order some and how many do i need and what kind of bulb becaussse there are several wierd shaped componet leds out there. I can worrry how im gonna get the dash off after i know what im ordering i want blue in color for mine. Pullling bunches of hair out at companies who say they do truck accessories......... when they say ohhh we dont do that and dont know what your talking about but you can do your own research, i just wanted to deck him one right there.
Old 04-15-2011, 08:02 PM
rick980's Avatar
I have something for you in you have a nav unit, I have a faceplate that needs a new screen...well I might be able to get a screen anyway it lights up RED. PM me send me your email or number.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 16 07-02-2016 05:36 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
2010 Console light for 2005? Danstona Custom Dodge Ram Interior and Exterior Lighting 12 10-06-2010 10:39 PM
Help w/OHD Console Light Buckee Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 11-18-2009 10:53 AM
