Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-05-2011, 07:24 PM
CloneSaw CloneSaw is offline
Vehicle: 2001 Dodge Ram
Trim Level: Sport 4x4
CloneSaw is on a distinguished road
Default Steering shake
Guys:
Whenever I go over a moderate bump at a higher speed my truck starts to shake out of control. It has became worse over the past few weeks. When ever i slow down it stops and doesn't really act up until i hit another bump. Any thoughts on what to look for/replace?
Old 04-05-2011, 09:04 PM
Sounds like theres something worn out in the front end . Possible track bar , tie rod end etc....
Old 06-03-2011, 06:58 AM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
I also am a member of TDR (Turbo Diesel Registery ) you need to check out the web site and search ( Death Wobble ) the site is tdr1.com....Lots of parts to start replacing.
Bodine
Old 06-06-2011, 09:46 PM
svetlecic's Avatar
svetlecic svetlecic is offline
Vehicle: 2011 laramie 1500 crew 4x4
Color: white monotone
Rep:13
svetlecic is on a distinguished road
What you are describing is what we like to call the death wobble. Their are many different opinions on what causes it. Usually it is caused by a worn steering stabilizer. But just replacing it with a new stock one is not going to last you very long. I would advise you to purchase a dual steering stabilizer kit from skyjacker or superlift. Its actually cheaper to buy the kit than it is to buy a singal mopar shock. It will take care of all your problems. Also if your steering linkage has not been updated to the newer heavy duty style you might want to check with your local dealer.
285/65/20 BFG , Weather tech floor mats and vent visors , Amp Research Power boards , Console Vault , Mopar side door moldings painted bright white , Avs aero skin bug shield , Daystar leveling kit , Many more to come!:smileup:
Old 06-11-2011, 10:08 PM
Muddbog's Avatar
Muddbog Muddbog is offline
Vehicle: 2007 Dodge Mega Cab 4x4
Color: 2 Tone Blue/Silver
Rep:20
Muddbog is on a distinguished road
Send a message via Yahoo to Muddbog Send a message via Skype™ to Muddbog
I have the same thing... DWdiesel.com sells a stabilizer for the gear box... but I am looking for a Heavy Duty steering linkage as you said. I carry a 8.5' western v-plow
2007 Dodge Mega Cab 4x4 5.7 Hemi
Old 08-08-2014, 07:04 PM
neanderpaul67's Avatar
neanderpaul67 neanderpaul67 is offline
Vehicle: 2000 Ram 2500 4X4
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
neanderpaul67 is on a distinguished road
Had death wobble on my 2000 after front=end damage caused by a drunk driver...while the truck was parked! Found that the newly=replaced track bar and left hub bearings were bad. Replaced the track bar with a Synergy replacement & update kit, along with changing bearings. Vast Improvement! No more death wobble!
Old 08-09-2014, 08:46 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Could be lots of things. Trackbar, misalignment, bushings, ball joints, or a combination. My buddy even had bad death wobble with some worn out tires and when he changed tires, no more death wobble. Get up under there and have someone turn the wheel whily you look for play.
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 01:23 AM
New Mods and a DIY for steering maintence sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:10 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 01:08 AM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 08:42 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 06:27 PM
