Old 04-06-2011, 07:07 AM
pirayaman's Avatar
pirayaman pirayaman is offline
Vehicle: 1987 le250 power ram
Trim Level: fully loaded
Color: 2 tone red white
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Rep:25
pirayaman is on a distinguished road
Default 3 inch body lift question on a 87 power ram
how will a 3 inch body lift affect the ride
seems like its gonna be bad replacing soft rubber mounts with hard plastic lift mounts but i have no clue
Old 04-14-2011, 12:44 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Haven't done this to the truck yet. But, experience on one of my past vehicles - things were stiffer with the nylon bushings. I'd expect the same with the mod you're looking at.
Old 04-14-2011, 03:15 PM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
It does not change the ride on bit. You do not replace the rubber bushings, you put the lift blocks on top of them.
4 Inch Rancho Lift Installed Pics! Dustinmc15 Dodge Ram Pictures - Photos 46 01-09-2013 04:39 PM
Rancho 4 inch lift rinkman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 03-07-2011 02:55 PM
Which Body Lift would be best? Zone or PA? ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 02-03-2011 09:10 PM
3 inch body lift 98 Dodge Ram tssiTanker Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 01-19-2011 11:53 PM
body lift question? pullin48 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 05-13-2010 02:08 PM
