Old 04-06-2011, 09:40 AM
Mikey88's Avatar
Mikey88 Mikey88 is offline
Vehicle: 2008 Ram
Trim Level: Big Horn Q/C 4X4
Color: Black Pearl
Rep:12
Mikey88 is on a distinguished road
Question Rear of truck not level???
Looking at the truck the other day and something seemed off. So I grabbed the tape measure and measured from the ground to the bottom of the wheel wells on the back of my truck. The drivers side is sitting about an inch lower than the passenger side. What gives????
Old 04-06-2011, 10:57 AM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Any chance you weren't on level ground?
Dillon-aka, The Little Kid
Old 04-06-2011, 01:14 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Its a little more accurate to measure from the center of the axle to the wheel well
Old 04-06-2011, 08:09 PM
mopower mopower is offline
Vehicle: 1998 dodge 1500 4wd
Color: red
mopower is on a distinguished road
stang is right!!! first get an accurate measurement if you are still off kelter and you havent been rompin around and twisted your frame i would check out your leaf spring shackel it will be on each end of your leaf spring connecting the leaf to your frame make sure it isnt broken
Old 04-06-2011, 08:46 PM
nate8604's Avatar
nate8604 nate8604 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT/Big Horn
Rep:36
nate8604 is on a distinguished road
Did you look and see if one sides tires have more air than the other. Not trying to insult your intelligence here but my wife's suv looked like this the other day and I checked the tires and the passenger side had about 15 psi less than the drivers side once the tires were inflated her vehicle looked level again.
Old 04-08-2011, 03:26 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Could have a blown shock too. Not likely with your truck only being 3 years old but that was the culprit in my case.
Old 04-08-2011, 08:55 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
That is completely normal. The older they get the more they lean to the drivers side. Its just a natural result of having more weight on the left typically than the right. Most people don't even notice but I do.
Old 08-09-2014, 07:12 PM
cbfodalo@live.com cbfodalo@live.com is offline
Vehicle: 03 Dodge Ram 1500 slt 4x4 quad
Trim Level: SLT Sport 4x4
Color: Atlantic Blue Pearl
Rep:20
cbfodalo@live.com is on a distinguished road
not to mention the gas tank is on that side too.
I fo u ND this answer on a different thread, makes sense that a load if fuel would sag rear to that side an 1" or 2"
03 Ram 1500 slt, 4x4, k@n CAI, dynomax uktraflo ss, leveled, TMR delete, catch can
Old 08-09-2014, 07:47 PM
Canadian Hemi Pride's Avatar
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Someone used the search function
Little late on the response, but the effort is what matters.
IG:@briley59
Team Bully's Performance
Old 08-09-2014, 10:52 PM
DetroitDoc DetroitDoc is offline
Vehicle: 2014 Dodge Ram
Rep:33
DetroitDoc is on a distinguished road
Shocks don't set ride height. Springs set ride height.
Rear End SHOT! BOSS 32V 5.7L V8 Specific Topics 3 03-25-2011 03:20 AM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 01:13 AM
Level truck? Ryank Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 11-11-2010 01:10 PM
Feeler: 2" lift kit, Bilstein 5100's and rear bock kit (06-08 1500) ScatPak07 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 10-08-2010 08:25 PM
Lowering rear of truck bones64 Dodge Ram General Discussion 9 02-09-2010 09:18 AM
