Old 04-06-2011, 11:21 AM
Krpto1973's Avatar
Krpto1973 Krpto1973 is offline
Vehicle: 2011 Dodge Ram 2500 4x4
Trim Level: Power Wagon
Color: Blue
Rep:71
Krpto1973 will become famous soon enough
Default Seats and Carpet Removal Question
I am trying to prepare for my complete audio installation (about 2 weeks away) and I am laying out my plans and came across a question about the seats.
Since I am doing a complete audio system (components in the doors, dash speakers, subs under the rear seats, amps under both front seats, and headrest monitors) I want to take apart the entire interior so that I can run all the wires proplery, instead of just snaking them around.
I thought I read somewhere else, that if I disconnect the seats without disconnecting the battery, I might cause the EVIC to throw some sort of code. I have no problem disconnecting the battery, but I may want to reconnect to test stuff, and the seats will still be removed. Will this cause me some sort of problem.
Also, is there anythign special I need to know about removing the carpet once I have the rest of the seats out?
If there are any techy guys out there that have been through this, or know anything about it, I would love the information.
Thanks
-2011 Dodge Ram 2500 4x4 Power Wagon
-2006 Suzki GSX-R 750, 2004 Triton Tr-19x
Old 04-09-2011, 06:07 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Well removing the seats prior to installation is a wise choice.You probably gona have to remove some moldings to get the carpet off so carefuly and gently pull those delicate molding clips off, last thing you need is a broken clip and no way of putting the molding back on. As for the seats not connected and possibly throwing a coded when testing stuff..... I say ohwell just reset the computer when seats are back on so sensors read normal.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Katzkins Leather Seat Upgrade Installation Write-Up Part 1 DoubleARS Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 11-29-2010 09:19 PM
Leather Seats Ripping, Carpet has a hole smartel 2009 Dodge Ram Forum 19 12-13-2009 10:11 PM
06-08 style seats? jjhwick119 Dodge Ram General Discussion 3 11-22-2009 03:32 PM
