Old 04-06-2011, 12:49 PM
ed22 ed22 is offline
Vehicle: 2006 Dodge RAM 1500
Trim Level: SLT LONE STAR
ed22 is on a distinguished road
Default Will this fit? Help please.
I am looking at:
18x9 rims with 0mm offset
wrapped in 305/60/18 Nitto Terra Grapplers
To go on my 2006 Ram 1500 quad cab 4x4.
Will they fit without spacers?
Thanks
Old 04-06-2011, 11:16 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Not sure about the 0 offset and an 18" wheel should work for you. I've seen posts referring to offsets of -22 for the wider tires. Hopefully someone else will confirm or chime in.
Old 04-06-2011, 11:19 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
That tires just about 12" wide and about 32.5" in theory. I think it would fit although its going to be a tight squeze.
They would definitly fit with a leveling kit and i'm pretty sure you wont rub on the control arms since its a little bit smaller then your typical 33x12.5
Hopefully someone else who has run this combo will notice your thread
Old 04-06-2011, 11:27 PM
Do you have a level kit on the truck? I'm thinking you will have no problem if you do have one. If not, I suspect you are gonna rub at the top of the wheelwell.
Old 04-07-2011, 12:13 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
That's what I thought.
Old 04-07-2011, 01:10 AM
I can easily get a level kit installed, but I was worried about the width as I don't like the idea of spacers or adaptors. As long as they will fit being a wheel with no offset, I am happy. I know you need about a -12 offset to fit a 325.
Old 04-07-2011, 01:56 AM
Color: Mineral Gray
Rep:177
You'll also need atleast a 9" wide wheel for 325
