Old 04-06-2011, 08:25 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
Default lacking n power not sure why
some of you might kno from my posts but so far my truck has had a full tuneup(plugs,wires,coil,cap,rotor) and also number 1 02 sensor. iac sensor and tps had been changed. i also have a spectre cai and a flowmaster 70 series muffler. with only 105,000 miles on her she just doesnt feel like its got the power it should. especially low end and at highway speeds. when i put the pedal to the floor off a deadstop it feels pretty slggish and i lose speed on small inclines at highway speed too. anyone have any ideas for me? just feel like there should be more power there.
Old 04-07-2011, 06:42 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
what's your gears? i'm running 3.55s and my 4.7 QC had more balls than this, but that's because it had 3.92s.
just a thought...
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-07-2011, 06:58 AM
sdram03's Avatar
Rep:52
just had a thought... did you do a compression check. not that it should need one, but i did one on a 440 i had in a 76 Powerwagon, cause it was kinda sluggish. sure enough, had 2 cylinders that were below spec and the rest were getting close.
Old 04-07-2011, 09:23 PM
Color: Dark Red
well as for gears i have no clue. my truck is a 2500 and ha tow and plow package and also my truck is 8800 gvw so rated as a 1 ton. so not sure what it has. and no i havent had a compression check done. might look into it when i have more money. only a 105,000 or so tho its hard to believe the motor or something could be that bad.
Old 04-07-2011, 09:42 PM
mattee's Avatar
mattee mattee is offline
Vehicle: 2002 1500 Ram QC 4x4
Rep:13
mattee is on a distinguished road
From what you listed you probably have 3.92s. I have the 3.92s and love it, my wife's durango has 3.55s and shifts out of overdrive whenever there is a slight grade on the highway. but to be sure there should be a sticker inside the glove box that tells you. Also make sure the trans has a clean filter and proper fluid level and the bands are properly tightened.
Old 04-07-2011, 10:00 PM
Color: Dark Red
thats pretty much what mine does. any slight grade i loss speed on the highway in od. tranny fluid and filter just got done a few thousand ago. only put about 11000 miles on since i bought it and it felt more ballsy when i first had it.
Old 04-09-2011, 09:29 AM
Ogre Ogre is offline
Vehicle: 1997 Dodge Ram 1500 4X4
Trim Level: Extended Cab
Ogre is on a distinguished road
I just bought my truck and believe me I understand what your talking about. My 97 feels a little sluggish as well and mine is only a 1500. But to be fair I do have a blown head gasket. So maybe after I fix that, refill the oil and coolant. Replace the plugs, cap, rotor, and air filter then maybe, just maybe I might be able to get some more power out of this truck.
Old 04-09-2011, 11:22 AM
the83judge's Avatar
the83judge the83judge is offline
Vehicle: 2001 Dodge Ram 1500 O/R
Trim Level: Off Road package
Color: dark green
the83judge is on a distinguished road
Yep, upgrade your gears. Even though my truck weighs 6400 lbs as a reg. cab 1500, it still will get up and move with the 4.10s. When I used to live in WA., I had to drive up a quarter mile fairly steep hill to get to my neighborhood and its the only vehicle out of the three that I own that never downshifted!
If you can't dodge it, RAM it!
Old 04-10-2011, 04:32 PM
Color: Dark Red
ya well iv wanted a posi for a while but i cantafford any of that right now. was hoping it might jus be a stupid thing to fix.
Old 04-10-2011, 08:44 PM
zxbud zxbud is offline
Vehicle: 1999 Dodge Raam 4x4
Rep:13
zxbud is on a distinguished road
I would install a new adjustable timing set so you can advance the cam 4 degrees or 1/2 of a cam sprocket tooth. Your cam chain is probably worn and sloppy which retards intake timing and causes the doggy performance you're talking about. 4 degrees advance renders instant off idle torque.
04 hemi seems to lacking power jerad Newbie Checkin! 15 02-26-2011 01:37 PM
Problems with power mhillips Cummins Diesel Specific Topics 1 01-27-2011 11:47 PM
air ram power wire 4doordodge4life Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 04-26-2010 10:37 AM
Won't Start!!! Please Help racer965 Electrical 13 01-21-2010 04:10 PM
New To the Forum/ lacking power J1M Newbie Checkin! 9 08-16-2009 08:53 AM
