Shift knob? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-06-2011, 10:49 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
Default Shift knob?
Hello, Does the shift knob on the Floor mounted shifter just twist off? I want to replace the large ugly one with a simple black round knob. Thanks
Old 04-07-2011, 09:54 AM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
hey I am going to undergo this task also
Apparently you can use a knife where the chrome bezel is and push down then use a screw driver to twist it open theres a thread on this somewhere on these forumz I was going to do more checking when my shifter comes in.
Old 04-07-2011, 03:16 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
first use a thin blade, like a thin putty knife, slip it between the the chrome bezzel at the base of the knob and the upper black part. Gentle push it down, it will snap free, and slide down....Oh yea, I almost forgot.... there is a very small tab on the consel, to the right side of the shifter, open this tab, and push down on the pinkish tab inside, this will allow you to move your shift lever into the neutral position with the engine off, making this whole process much easier, anyway back to the removal..once you have snapped the chrome chrome bezzel loose, you will find small fingers protruding down from the black part of the knob onto the shaft...gently pry those fingers away from the shaft while pulling straight up on the knob...it will pop free and come straight up and off....don't forget to re cover your little tab opening...now you will have access to the shaft to do what ever you want....there are losts of choices...
So it is written ! So it shall be done!
Old 04-07-2011, 03:39 PM
Trim Level: R/T
Rep:60
Thanks, I'm going to try this over the weekend. Can I use any shift knob I like or does it need to be a specific thread size? Thanks!!
Old 04-07-2011, 04:09 PM
Rep:27
The shaft is not threaded, there are some companies making sleves that fit over the stock shaft, so you can add a threaded knob, and there are companies making shift handles that are secured by Allen set screws onto the stock shaft... You should do some research to find what you want.. I used a Hurst system made for Chrysler cars, very nice but very pricey also
Old 04-07-2011, 05:30 PM
Rep:2964
I believe that i read that the new Challenger shifter looks good
these are what some challenger members are doing
http://www.challengerforumz.com/show...12&postcount=1
http://www.challengerforumz.com/show...5&postcount=13
http://www.challengerforumz.com/showthread.php?t=48183
another T handle idea, with install pix
http://www.mylrs.com/blogs/lrs/archi...hallenger.aspx
other Ram parts, Canadian shipping too
http://www.latemodelrestoration.com/Dodge-Ram
error code list moparmike07 Dodge Ram Knowledge Base 17 12-01-2017 11:12 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
R/T Shift Knob 09 RT RAM Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 13 02-10-2011 02:31 AM
chrome shift knob kool ram 2009 Dodge Ram Forum 2 09-04-2010 06:21 PM
Shift knob 6spdBBR Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 05-03-2010 09:47 PM
