Old 04-07-2011, 10:47 AM
jeepinjk jeepinjk is offline
Vehicle: 2008 Jeep Wrangler
Trim Level: Ohio
jeepinjk is on a distinguished road
Default Axle Width
Ok, I have tried to search and can't come up with an acceptable answer I am looking, close but no quite close enough.
I may catch some flak, but oh well. I am looking for the axle width of a front Dana 44 axle for the 2nd gen. No this is no going back into a dodge it will be going into my Jeep Wrangler. I have a high pinion D30 there now and it can handle 35's, but its a thin walled axle and prone to bending (mine already has). My current axle width from hub to hub is 65.5 inchs plus I have 1.5 inch spacer so right now I am at 67inches even. I have found a D44 from a ram is 61 inches from ball joint to ball joint. As long as the axle is 65.5 in width I can make it work. Its a potential bolt on for a cheap upgrade. Currently aftermarket D44 axles are right about 3 to 5 grand. My junkyard has em for 150 bucks. Any info would be appreciated.
Old 04-14-2011, 01:36 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Well I'm not sure, I was hoping that someone would answer by now, but, the post has been empty so far. From what I've seen in spec sheets the width of the RAM is a few more than the Jeep. There are a lot of custom axels out there but as you said the $$$ is a big difference in what you can pick up in a junk yard.
Front Axle Replacement Leadchunker Dodge Ram 4x4 - Offroad Discussion 4 01-21-2011 11:23 PM
Axle manufacturers weight rating? WesGPS Dodge Ram General Discussion 0 10-04-2010 03:48 PM
Help needed for axle rating question please. WesGPS Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 09-23-2010 03:01 PM
front axle 99 ram slt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 01-14-2010 07:40 PM
Front axle leaking after u-joint change LittleMoe Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 11-15-2009 10:05 AM
