Side pipes? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 > Exhaust
Exhaust 5.9L Exhaust Discussion
Old 04-07-2011, 09:53 AM
JustiNeal 97's Avatar
JustiNeal 97 JustiNeal 97 is offline
Vehicle: 1997 Dodge Ram 1500 4WD
JustiNeal 97 is on a distinguished road
Default Side pipes?
Hello all I was looking at getting a new exhaust for my truck. What i really want are side pipes that come out on both sides right before the back tire. My truck is a 97 1500 5.9 single cab short bed. Any help is greatly appreciated. Thanks!
Old 04-07-2011, 10:25 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i had that idea a while ago, but gave it up after seeing how much work it would take.
good luck tho. if you ever get it to work, i wanna see it!
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-07-2011, 10:42 AM
Ok thanks. did you find a company that makes a kit or will i have to go custom?
Old 04-10-2011, 10:29 AM
sdram03's Avatar
Rep:52
well, i found the sidepipes, but the rest of the exhaust work would have to be custom. i was gonna do it myself, but didn't like how i had to run the exhaust piping. the frame gets in the way. would have looked ugly. i imagine i could have used a torch to cut some other things out of the way, but that's more work than i wanted to deal with.
i guess if you really want to change how the exhaust routes off the headers or whatever, then it may work. but i had future plans that involved leaving a lot room in certain spots. that may not be an issue for you.
Old 04-10-2011, 11:20 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
A local exhaust shop could bang that out no problem! Check around and see what you come up with!
Old 04-10-2011, 12:56 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Thats what i was going to do, but when i talked to the shop they said i couldnt because the gas tank is on the driver side and it would interfer with the exhaust.
Carven exhaust, K&N CAI, Leveled with wheels and tires, Sundown & Skar audio.
Old 04-10-2011, 01:36 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
I had a set like this on my '94 GMC...it was lowered so I couldn't put the shields on....where the doors hinge, the 8" piece that's a different rust color was my Y for my DMH cutouts
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT CAI, custom tune, custom exhaust
Old 05-11-2011, 12:18 AM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
i taken my ram to 3 exhaust shops none will do it before each rear tire..gas tank issue or some bullshit excuses.. only way i was told was if i switch to glas packs and to go true duals.. so they could run it basically under each door and out each side.. staying away from the gas tank. me personally dont like glass packs.. always been a flowmaster kind of guy or straight pipe.. so if i was to do it it go straight pipe.. but when i had my mechanic run some straight pipes on my truck it was really loud and great sound.. but to loud and i had a few problems with the neighbors. and a few cops so i bought the flowmaster super 10.. loud but not cop and neighbor issue loud lol!
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 05-11-2011, 09:06 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
u can get the cherry bomb shorty mufflers if u wanna run tru duals. there not considered glass packs and they are used on the new camaro and challanger kits. these would be ideal for side pipe exhaust but the issue with the frame being in the way is rather expensive to get around
Old 11-13-2011, 02:14 PM
RamRunner4x4's Avatar
RamRunner4x4 RamRunner4x4 is offline
Vehicle: 1998 dodge ram 1500
RamRunner4x4 is on a distinguished road
tell them to run them along the outside of your truck frame(or chassis =)) thats what ill be doing, i have the pacesetter long tube headers straight piped right now then going with an x-pipe right after my T-case then 2 magnaflow mufflers then tubing bent to come out in front of my rear tires. the gas tank doesnt get in the way if you run them along the outside of your frame.
If You Aint First, Your Last.
exhaust, side pipes
2011 ram 2500 leans to passenger side garyk LD RAM - General Discussion 7 09-15-2011 08:11 AM
Poor floor heat on drivers side Quiet Lunatic 2011 Dodge Ram Forum 7 02-27-2011 01:24 AM
trail grappler side was opinions FDBDW Dodge Ram Wheels And Tires 14 02-19-2011 12:47 PM
On the front lower A arms: why are the drivers side and hpc3 2010 Dodge Ram Forum 1 05-23-2010 10:14 AM
Side Pipes atvredneck13 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 15 01-25-2010 01:14 PM
