Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-06-2011, 11:53 AM
WendysOrBust
Default Trans maybe fuel problems?
I own a 2004 Laramie 4x4 2500 and my truck is having some issues while driving. What happens is that while I'm driving it'll jerk pretty violently between gears. It started doing it while cursing at ~20mph in neighborhoods. It felt like it would jerk from 1st to 2nd and would eventually pick one and would lock itself in that gear. Meaning it wouldn't down shift or upshift until turned off.
However this morning it did it while I was driving at 65mph on the highway. It dropped to 3rd then 4th and finally it would just leave it in neutral until turned off.
The truck idles and drives fine (with the obvious issue stated above) it doesn't burn oil or coolant and the tranny oil seems fine as well.
Any ideas were I could start?
Old 07-08-2011, 05:41 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
I see this was your first post, drop by the Newbie Checkin and say hi!
Old 07-08-2011, 05:55 PM
No codes showing? If the transmission is shifting and when it does, that is your first indication of a change, I'd check out the transmission control module or have the PCM scanned.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 10:22 PM
96 Ram refuses to start. Fuel pump problems? Derek 5.9L V8 Specific Topics 9 11-28-2012 04:06 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
