Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 04-08-2011, 08:12 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Default Woohoo another overheating thread
My truck has been running hot these past few days. Last night I put a new thermostat in and tested the old one. It would open very slowly in boiling water and only about halfway after ten minutes.
Now that I got all the air burped out it is still running hot.
I feel cool spots on the radiator where there is smooth airflow, ie not behind the transmission or power steering coolers. Behind those it is hot.
I can hear a short squeak coming from the water pump area. At first I thought my radiator was plugged, but now I am worried about the water pump.
It is only about a two year old pump.
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 04-08-2011, 09:27 PM
Are your hoses heating up?
Old 04-08-2011, 10:21 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
^^+1,
by cold spots on the radiator, do you mean you can actually touch those spots? then you got a blocked radiator. get it flushed and checked.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-09-2011, 12:58 AM
Rep:91
Yeah they are cold. The tanks and hoses are hot and the fins are cold.
Old 04-09-2011, 01:00 AM
Rep:91
I am going to flush it tomorrow. If that doesn't work I guess I wouldn't mind dropping a new rad in it.
Old 04-09-2011, 01:13 AM
Rep:2705
you should pull the radiator & take it to a radiator shop
they will remove the upper & lower tanks, dip everything into a vat of chemical solution, then they take a metal rod & push all the gunk out of all the tubes, after that the again dip it in the solution & then blow water & air through each tube & put the tanks back on
if it looks like your radiator is bad, they will let you know before completing the job
IF you use the vehicle for towing, they may ask you if you want a 3 core radiator, instead of a normal 2 core
Old 04-09-2011, 01:18 AM
Rep:91
I can't drive it to a radiator shop if I take it out! Flushing it tomorrow
Old 04-09-2011, 07:40 PM
Rep:91
Went ahead and put a new radiator in. Figuring that a lifetime warranty aint so bad! Since i have an 800 mile trip coming up towing a trailer i am not going to chance anything
Old 04-09-2011, 11:45 PM
Rep:91
Cooling problem solved! And it looks better as well. The old radiator's paint was flaking off and the plastic tanks were looking aged. I think I prefer the unpainted one. Am I crazy for that?
Old 04-09-2011, 11:57 PM
Rep:2705
actually, the unpainted fins cool better, on my old '56 chevy 3200, only the tanks were painted
same thing goes for an engine that is unpainted, but, they always get painted any way, if you ever open your hood to show it off
Dodge Ram Lift/Tire Setup Thread Brandonbstang65 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 724 10-03-2015 04:15 PM
Black Mamba's Mod Thread Juice420 Custom Dodge Ram - Complete Builds 79 11-06-2012 10:34 AM
2012 Ram Calender Picture Submissions Thread BlueJet Dodge Ram Pictures - Photos 46 09-15-2011 05:05 PM
2011 Ram Calender Picture Submission Thread BlueJet Dodge Ram Pictures - Photos 51 10-16-2010 02:01 PM
Thread Follow up 2010Ramowner Dodge Ram Forum CANADA 3 04-06-2010 01:25 PM
